OBX header install
Old Jun 17, 2015 | 10:50 PM
holywha's Avatar
holywha
Default OBX header install
I recently completed a home garage install of OBX stainless 1 7/8 headers with xpipe on my 09 coupe and thought I would provide some feedback since I researched here myself before purchase. I purchased them from Cajun at berlsx.com and despite getting off to a rocky start, he did have a nice price and made good on everything I had an issue with. I would buy from him again. The headers were shipped loose in a big box with minimal protection resulting in some minor dings and flanges that had to be rebent into shape. This is not Cajun@BER's fault but the shippers. The o2 extensions that were shipped were a square connection. I ended up ordering the correct trapezoid ones from Summit Racing and Cajun@BER reimbursed me the expense. I do not have impact tools and only used jackstands. It was a bear, but do able. You will want help! I ended up cutting the passenger side cat pipe to get it out. Install was pretty easy and everything fit without a lot of coercion. I picked up a couple of stainless band clamps, but reused the stock gaskets and bolts. System sounds great with the NPP stock axleback.
Old Jun 17, 2015 | 11:14 PM
brewcitygymratt's Avatar
brewcitygymratt
St. Jude Donor '13
I also have obx on my heads/cam 06 and the fit finish and build quality were top notch.
Old Jun 18, 2015 | 10:06 AM
Dano523's Avatar
Dano523
ARP header studs with nuts makes installing the headers from the bottom a snap (give you something to hang the gaskets, then headers on when you are installing them from the bottom of the car).
The stock hardware that comes with the full kit, throw them and the new manifold gaskets in the trash. The old manifold gaskets work fine, and as for band and bolts, get quality band and hardware instead.
As for the cats that come with the kits, work fine, but the clamping them in place is less than desirable. Instead, use the clamps that come with the kit to just hold them in place on the X pipe for fitting, do a couple of tack welds to hold the cats in position on the X pipe, then pull the X pipe to do full welds the cats in on the X pipe (read 2 seams that you don't have to worry about leaking down the road).
As for rear O@ sensors, they get deleted in the tune, so when you are picking up hardware to replace the crap import hardware that you are throwing away, make sure to pick up two plug bolts for the rear O2 sensor ports not going to be used to cap them.
Old Jun 18, 2015 | 11:59 AM
Carlosgtsr's Avatar
Carlosgtsr
Cruising
Good to hear they worked good for you. I don't know why corvette guys are so ashamed to buy them. My car has ARH but only because my brother bought them. Some pics would be awesome if you can post them.
Old Jun 18, 2015 | 01:21 PM
Speedforhire's Avatar
Speedforhire
Sounds like they fit better than the LG's I got.
I need to upgrade to 1 7/8's so I may do the same.
Old Jun 18, 2015 | 09:59 PM
Brandon619's Avatar
Brandon619
I almost went with a set of OBX headers but bought a set of Texas Speed headers instead. I'm still debating if I want to install a set of cats.
Old Jun 18, 2015 | 11:03 PM
holywha's Avatar
holywha
I should have taken more pics. The welds were surprisingly good. Getting the old manifold out was really the hardest part.
Old Jun 19, 2015 | 12:24 AM
Dano523's Avatar
Dano523
OBX headers are natural on the corvette (very good clone of a great designed header),
Think of it like other OEM parts on the car that are not made in the USA, but are just installed on the car using USA labor force instead.
Old Jun 19, 2015 | 09:57 AM
Brandon619's Avatar
Brandon619
These are a good looking set of headers!
Originally Posted by holywha
Old Jun 19, 2015 | 10:56 AM
05Z51C6's Avatar
05Z51C6
Post a sound clip.
To OBX header install
