2008 Auto: Short story. Last night I drove about 2 miles to Subway. I went in and got what I needed & when I started my car & put it in reverse it did not move, so I tried all gears and nothing. No gears would engage. The shifter moves like it is not connected to anything. I left it there & got a taxi home. The years I've been on this forum I have not heard of this problem....Any help would be much appreciated. Thanks........................
DANO: Can I get those parts at a auto parts store?
Start with pulling the shift cable and see what is wrong with it.
If the problem is the inner ridge loop grommet that has worn out and why the cable end is popping off, then yes, you should be able to go any auto parts store to look in the aftermarket clip selection isle to find a replacement grommet in the correct size to replace the worn grommet on the cable end loops.
Here is the factory cable, and as you can see the ends have loop grommets that can be removed if the inner ridge section has worn out, and then the above type grommets use to replace them.
Or, since the shift cable is only $40, just order a new cable and save the time and effort of having to shop for the needed grommet and replacing it in the old cable.
Myself, if it was just the grommet center ridge that was worn down, have the needed tooling to just heat up the plastic grommet to reform the inner ridge instead.
Cherokee Nation, did you ever determine the cause of your problem? How many miles on your car? I have a 2008 also, so I'm curious.
Dano, do you think this might be a PM type item since it's only $40?
I had it towed to the dealer from where it quit. (Sorry Now That I Did) The dealer ordered a cable for it without even looking at it & that was last Thursday. They think it snapped,,BS"..I don't know how they are going to get it to a service bay when it is stuck in PARK & sitting in back of the lot?? I have 68000 miles on it PDs Vettes;........
Did you by any chance have your shifter "stick" or would not engage anytime before this happened?
Over time the C6 shifter unit does fail -- the first symptoms are intermittent "harder than normal" shifting in reverse ( will not happen all the time -- many just think it is because of how they parked or it is the weather ) ... eventually it will progress to a point it will take several tries to get the shifter to engage... then finally total failure. The cable is frequently damaged because the driver forces the shifter to engage....
The shifter unfortunately cannot be repaired and when it fails, much be replaced.
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I had my cable break right about the same mileage ,,,
Think it cost me about 250 out the door... And my dealer had my car delivered to me 1.5 hours away ..... Good to have a great relation ship with your dealer....
No sir, I've have never had to jerk or force it into reverse or sport.What I think is that when I'm at a taco joint and others places & if there is a few cars in front of me I move to park & shut it down. I do that until I get to the window to order my stuff. So my shifter gets a lot of use, even in traffic I will move it to "N" because of the cam causing a little jerking when in gear & that is not good. Those parts are 8 years old down there now...
With the age of the car, would bank that it was one of the end of cable grommets that when south, and the cable popped off the end point shafts for the cable.
Really, it comes down to three parts.
The mostly plastic part shifter assembly itself, and with age and the heat in the torque tube tunnel, the plastic parts in it can go brittle and fail.
The cable, and again with the heat in the torque tube tunnel, plastic end pieces on the cable go brittle and snap.
The trans itself, with the shift linkage inside the trans going south instead.
If you want to weed out the first two, just get under the car and shift the shifter to see if the trans linkage shift shaft on the side of the trans is moving or not.
Dano,I've had Borla Stringers on my 08 since new and the mufflers and pipes are very close to the tranny,so I'm thinking all that heat may have caused the plastic think to break or ??..I hope that is is only the cable....
It's quite possible, but unlikely, that the nut that holds the lever on the transmission backed off and the lever fell off. Fix time 1 minute labor, zero parts.
There's also a clip on the cable at the trans end for adjustment that could have popped off and allowed the cable to become disconnected. Fix time 1 minute labor, $.29 part most places or $16 at a dealer.
However, with all the continuous manual shifting, I'd suspect other parts.
Those taco joints and Subways are hard on shifters. You either need a driver mod or different food choices.
