Delrin Bushing System for C6 Corvettes From Ridetech
Old Jun 18, 2015 | 10:20 AM
chase@ridetech's Avatar
0chase@ridetech
Former Vendor
Default Delrin Bushing System for C6 Corvettes From Ridetech
C6 Corvette Delrin Bushing Upgrade
If you are looking to get more performance and handling capability out of your C6 Corvette Ridetech has you covered!
With very few upgrades you can turn a C6 into a highly competitive track animal. One modification that should be on every corvette owner's list is getting rid of the factory spongy control arm bushings.
Today's Corvette drivers demand maximum performance without compromise and RideTech’s new direct fit bushing system will leave you with unrivaled control. Our “Direct Fit” technology makes upgrading your bushings a “DIY” breeze thanks to precise machining and included hardware. Now you can take those curves with confidence.
We have done a significant amount of testing on our track and road cars and have seen better lap times and more predictable handling. The delrin takes out the deflection that plagues the rubber bushings.
FEATURES
• Delrin bushing design eliminates control arm shift common with factory bushings.
• Reduction in deflection creates consistent and predictable handling.
• Trunion design captures bushings from both sides increasing strength and rigidity in
upper arms.
• Designed to resist binding at extreme alignment settings.
• Includes new trunions CNC machined from 4130 chromoly.
• No modifications necessary.
• Replaces all 16 control arm bushings.
• Split bushing design for easy installation.
Part# Price
1997-2013 C5/C6 11519500 $750
2006-2013 C6 Z06 11519501 $900
check them out here:
http://www.ridetech.com/store/c5-cor...shing-kit.html
