I had a question regarding the EWP and UDP being used at the same time , has anyone had any issues running them both at the same time, any problems with the car throwing codes, did you switch battieres, run a higher capacity alternator?
EWP if installed correctly with the proper controlled is a great idea.
Under drive pulley has no effect on cooling, regardless of cooling system set up. It does however can have a significant effect on your charging system. Try to avoid extended idling periods and check all power and ground terminals for corrosion.
