Fueling issues
Old Jun 24, 2015 | 09:59 PM
Bigboost954's Avatar
Bigboost954
Default Fueling issues
Well I finally had my cam, installed in my 2010 corvette grand sport so I took it over to get tuned well I got news that my fuel pump is dying out up on the top end around 6,000 rpm range only mods I have is kooks 1-7/8" headers catless, 3" mid pipe out of z06 axle backs and a halltech 103 cold air intake, BTR stage 4 cam could I be running out of fuel already with my mod?
Old Jun 24, 2015 | 10:58 PM
zali0104's Avatar
zali0104
How was the fuel pump deemed failing? By the fuel trim leaning out at stated rpm, or low fuel pressure?
Stock pump should make 600+ to the wheels.
Old Jun 25, 2015 | 09:02 AM
Bigboost954
Fuel pressure was fell right down at 6k rpms. Not sure if this helps
Old Jun 25, 2015 | 01:43 PM
Dano523's Avatar
Dano523
Fuel pump should be fine to 600hp, and the quick way to tell if the pump is going to bad, was there a huge drop in fuel pressure at the rails to begin with?
So on that note, what size injectors,
and what is the fuel pump and injector settings in the tune.
To Fueling issues
