Heater/AC blower motor inop
My 2008 4LT Convertible blower motor won't turn on. The control panel indicates the fan is on and the AC compressor is running. This has happened before and then somehow fixes itself and runs normally. Has anybody had this problem before and what was the fix?
Update: when all else fails, hit it. I opened the fuse block in the engine compartment, pulled the fuse out and put it back in and then tapped the relays a bit. Started it up and Voila! blower motor working fine. Must be a sticky relay or dirty connections in the fuse block
If you look we Both posted at the same time 9:03pm your last edit was the same time I posted so I didnt see it, anywho I was just trying to help you out glad you found your problem. Unplugging he battery works wonders for these cars when something is not working correctly lol.
