C6 grand sport clutch problem
The clutch pedal has a assist spring on it, and once you have the pedal past center point down, the spring is actually pulling the pedal to the floor (why the pedal sticks to the floor).
As for why it happened (master cylinder went out), GM went the land of plastic parts for producing costs cuttings, and it is, what it is. If they are picking up the tag for this repair, factory mastery cylinder is fine.
Down the road and you have to pick up the tab instead, go to the Tick metal master clutch cylinder instead.
Having them put it on a flatbed along the road where 20 K cars are going by.
Oh well, Crap happens. The worst part was that one of the guys I was with owns a Chevy dealership and not the one they towed it to. He even helped puch it ont he flatbed wrecker. Good man.
Yes, no, maybe.
the end plunger on the push rod has a cap that snaps on to hold it in place. So on low mileage cars, its just the cap that was not snapped on correctly when it was assembled the reason for it to fail so quickly.
On higher mileage cars, the problem comes from the clutch fluid black and thick as mud instead. There are three orifice restrictions in the clutch line to prevent you from abusing the drive line (slow down the engagement of the clutch), and since the thicker the contaminated fluid, the slower it going to return back to the master cylinder from the slave cylinder. So again, clutch pedal has a assist spring, and as the clutch pedal comes back up past the half way point, the pedal is going to be pulling back hard on the plunger rod, which can cause the end cap to pop off instead.
Worst yet, since the walls of the master cylinder are plastic, the more contaminated the fluid is with clutch dust (get in from the slave cylinder), the faster its will wear out the plunger and walls as well (pushing the pedal in does nothing instead).
Bluntly, you should doing the ranger method to keep the clutch fluid clean to begin with (fluid should be a light amber color at most, with no solids either floating on top, or in the bottom of the tank).
Jerry
the end plunger on the push rod has a cap that snaps on to hold it in place. So on low models cars, its just the cap that was not snapped on correctly when it was assembled the reason for it to fail so quickly.
Take Care of Your Clutch--the Ranger Protocol - YouTube
When I got it, I had the hardest time figuring out why my second gear was hard to engage. I had a few threads back in Dec. Lots of suggestions. One of those was to check the clutch fluid. When I did, it had black gunk swimming in it and it was just as dark as oil used. Started doing the ranger method and I think its all clear now. However this was not my tranny issue. I tried swapping the tranny fluid and diff fluid. Well that didn't help much. At the end, I install a CAGS bypass and that took care of the problem.
On a side note, the service manager said we shouldnt be changing the clutch fluid as often. Maybe twice a yrs or less because every time you open the reservoir, it catches humidity. True?
https://www.corvetteforum.com/forums...-pressure.html
Thanks in advance
Riverrat68
