Diff help
Old Jul 2, 2015 | 05:35 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Diff help
I have an 06 auto base with 22k miles on it and 0 modifications.
I got the car with 17k on it and noticed some chatter from the diff when I take a slow turn. So I read to change the fluid. I changed the fluid with Mobil 1 LS synthetic 75w. Did figure 8s and about 100 miles of driving. Still some chatter. So I Took it to Chevy and had them change the fluid. I'm not 100% convinced they did. I think they just put in more additive. So about 3000 miles has gone by and I am still getting the chatter. I drained the fluid to see if anything has been damaged or if I have a bigger prob then I thought.
So I ran a magnet through and the sediment shown is aluminum. Prob from the threads when I stuck my finger in the drain hole.
My question I think is, do I just keep changing the fluid until I get something that works or do I take out the diff and inspect it etc.? Also am I hurting anything by driving in this condition? What are some signs of trouble under normal driving that will indicate it's not just the fluid?
Old Jul 2, 2015 | 05:43 PM
djbrun's Avatar
djbrun
I would start by using the GM LS diff fluid that doesn't require the addition of friction modifier. Fill it yourself, so you know it was done right.
For the hell of it, check your axle nuts as well.
DJ
Old Jul 2, 2015 | 05:49 PM
djbrun's Avatar
djbrun
Dextron LS Gear Oil 75w-90 no additive needed #88862625
DJ
Old Jul 2, 2015 | 05:50 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Thanks. I did check the axle nuts before and they are torqued to spec.
I bought royal purple 75w to refill. I was not able to get to a dealership today. Anyone have luck with the royal purple?
Old Jul 2, 2015 | 05:57 PM
HBsurfer's Avatar
HBsurfer
The GM TSB for the diff chatter says to use this. It has worked for the rest of us. Like posted above, do it yourself and use this fluid. You can get it on line for about $25 per quart. No additive required.
Old Jul 2, 2015 | 06:00 PM
zali0104's Avatar
zali0104
Dexron LS Gear Oil 75W-90 does not use an additive. Actually a friction modifier will result in reduced oil performance. The particles in your oil is from but not exclusive to bearing failure. Regardless a tear down and inspection is necessary.
Old Jul 2, 2015 | 08:32 PM
timd38's Avatar
timd38
Red Line 75w90 has the friction modifier included. That is what I have used in my cars for 15 years. Putting in my Vette at 1,000 miles when I put the Quaiffe and new gears in 7 years later, the inside of the diff still looked new.
Old Jul 2, 2015 | 08:48 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Ok I am going to hold off on filling up until tomorrow and get the gm fluid. So no more talk on the fluid.
Let's get to the bearing comment. If it was a failing bearing wouldn't I be hearing a whine? All I am getting is a chatter when I turn.
I have noticed a sound when I go over bumps and thought this may be a wheel bearing or wheel hub. Would that make a similar chatter on slow turns?
Old Jul 2, 2015 | 08:51 PM
timd38's Avatar
timd38
You could have a rear bearing going, but that would not account for the look of the fluid. Rear bearings are harder to check because the axle interferes with rotating it.
Old Jul 2, 2015 | 08:53 PM
zali0104's Avatar
zali0104
Not wheel bearings, differential carrier bearings. When damage gets bad enough you will hear a whine under acceleration.
Old Jul 2, 2015 | 08:58 PM
djbrun's Avatar
djbrun
Are the particles magnetic?
Old Jul 2, 2015 | 09:01 PM
zali0104's Avatar
zali0104
No, steel is not magnetic.
Old Jul 2, 2015 | 09:03 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I think the shavings are from the drain plug threads. When I shone a light up into the drain I could see at the back end of the hole, metal burs like when you drill a hole and it's burred on the back side. I stuck my finger in and ran it 360 in the hole and that is when the shavings came out. I don't think the shavings were sitting in there and drained out with the fluid.
Old Jul 2, 2015 | 09:04 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
It's aluminum shavings. And steel IS magnetic. Aluminum is not.
That's what makes me think it's from the housing and not a bearing or internal part.
Old Jul 2, 2015 | 09:06 PM
zali0104's Avatar
zali0104
Maybe you should google it
Old Jul 2, 2015 | 09:19 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I'm aware that some steel is not magnetic.
The metallic atoms in an austenitic stainless steel are arranged on a face-centered cubic (fcc) lattice. The unit cell of an fcc crystal consists of a cube with an atom at each of the cube's eight corners and an atom at the center of each of the six faces. In a ferritic stainless steel, however, the metallic atoms are located on a body-centered (bcc) lattice. The unit cell of a bcc crystal is a cube with one atom at each of the eight corners and a single atom at the geometric center of the cube.
Old Jul 2, 2015 | 09:23 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
What components of my diff is an alloy with nickel concentration, as well as manganese, carbon and nitrogen, so it is able to maintain an fcc structure making it nonmagnetic.
To Diff help
Old Jul 3, 2015 | 10:32 AM
djbrun's Avatar
djbrun
Did you mean the type of steel used in the diff bearings is not magnetic? Because steel in general is magnetic, but not all steels are magnetic.
Even 400 series SS has magnetic properties, 304 series however is not.
Do you happen to have a part number for the bearings?
DJ
Old Jul 6, 2015 | 01:28 PM
cclive's Avatar
cclive
Honestly, I don't think there is any problem. The Mobil fluid is not a good replacement for the Dexron LS, so I would expect some chatter to continue there. The particles you see are not much and because there is no filter, they have probably been floating around in there since the diff was first manufactured. To me, this is especially likely since they are not magnetic. Yes, some steel is not magnetic, but not the type of steel used in gears and bearings. That steel IS magnetic and so it is not these particles that you are seeing. These particles are likely aluminum leftover from the original manufacture of the diff housing assembly. Bits of soft aluminum like that can't scratch and damage bearings and gears because they are soft and the bearings and gears are, by definition very hard, so to me, they are nothing to worry about.
Old Jul 7, 2015 | 07:23 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I changed the fluid and it has been 3 days now. There is 0 chatter in the corners now and it seems to be engaging properly under load. I think it is insane that it is so finicky with the fluid, but now i know ac delco only!
Thanks for anyone who chimed in moral support is always appreciated.
