Key fob help. Desperate
Old Jul 21, 2015 | 05:45 PM
Buddyleerc51's Avatar
Buddyleerc51
Cruising
Default Key fob help. Desperate
Ok. Here goes
2005 Daytona orange baby with 11000 miles.
Stuck in garage
I lost 1 fob and the trunk key. 2nd fob wasn't recognized Battery eventually died. Bought new trunk key through dealer and replaced battery. Fob still not recognized. Tried to begin reprogramming sequence. Turned key 5 times but won't see fob
HELP
I'm stuck. Can't drive my car
If this is in the wrong section, can moderators please move . Thank you
Last edited by Buddyleerc51; Jul 21, 2015 at 06:34 PM. Reason: Possible wrong section
Old Jul 21, 2015 | 06:33 PM
RicK T's Avatar
RicK T
Are you following the instructions found on this Forum? Note that this thread has 21 pages of troubleshooting help, suggestions and fixes.
https://www.corvetteforum.com/forums...tructions.html
After turning the key 5 times, does the DIC show anything? Or are you saying that turning the key 5 times doesn't do anything?
We need to know exactly what's happening, or not, in order to help you.
Old Jul 21, 2015 | 06:43 PM
Buddyleerc51
Cruising
Turned key 5 times and dic is looking for fob but will not recognize the one I have
Old Jul 21, 2015 | 07:13 PM
RicK T's Avatar
RicK T
So if it doesn't recognize it you need to go ahead and program it. Just follow the steps in that link I posted. You can do the short version, steps 1-10, to add that FOB as whatever number is next and get the car drivable then after getting a 2nd FOB you can go back and do the long procedure to reprogram both FOB's as #1 and #2 to give you access to the memory functions.
Old Jul 22, 2015 | 08:34 AM
psp6158's Avatar
psp6158
Did you put the fob in the slot in the glove box? That will get your car running... Or should. Good ideas above, and have you had any lights on your dash? A LOT of issues when the battery starts to die...
Old Jul 22, 2015 | 10:51 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Exactly. Dead battery or not.. put the fob in the slot on the left hand side of the glove box and the car should start. This precisely why it's there.
Old Jul 22, 2015 | 03:52 PM
Buddyleerc51
Cruising
Car does not recognize fob when inserted in glove box. New battery in car and in fob
Old Jul 22, 2015 | 03:55 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Has the 2nd fob ever worked with the car?
Old Jul 22, 2015 | 05:12 PM
Buddyleerc51
Cruising
Yes. Everything was perfect until battery died. Then I realized I couldn't get into car because I lost trunk key.
Dealer cut new key based on vin. Got into car. Replaced battery. no luck
Old Jul 22, 2015 | 09:43 PM
psp6158's Avatar
psp6158
Sounds like you've done everything I can think of, all I got left is the battery in the fob upside down or the fob in the slot with buttons facing passengers side... I'm sure you've checked those though
Old Jul 22, 2015 | 11:06 PM
Buddyleerc51
Cruising
I've checked the battery several times.
Loosing my mind
If the car doesn't recognize my only fob, is there a reset or am I stuck with the dealer
Old Jul 24, 2015 | 10:42 AM
psp6158's Avatar
psp6158
OK, came up with one more idea, buy yourself a new fob, CULTRAG or there are a couple in the for sale section, when you get it, try to program it, it will be #3 so it won't do your seat settings etc. (You can do the long version later) and see if it works. If it does, great, if not, off to dealer and you would have two fobs like you should anyway... Now I'm out of ideas lol. Good luck
Old Jul 24, 2015 | 05:28 PM
Buddyleerc51
Cruising
Ok. So drivers window doesn't go down because fob not recognized
I start the reprogramming process. It flickers "wait 10 minutes" then returns to fob not detected
These cars are brutal. Whatever happened to a simple key
Old Jul 24, 2015 | 08:57 PM
psp6158's Avatar
psp6158
It's got to be the car battery... Do you have it on a tender? Try the fob in the slot and jump the car. I've seen new battery on threads many times and it was a dead cell or car sat for a couple days with no tender on it and battery drained. Please figure it out,driving ME nutz and not even my car lol
Old Jul 25, 2015 | 09:21 PM
Whisky's Avatar
Whisky
It's possible the reader went bad. My 08 did this same thing. Reprogramming the fobs would not work. A trip to the dealer was in order.
Old Jul 26, 2015 | 07:24 AM
Buddyleerc51
Cruising
If I can't get the drivers window down how can I start the reprogramming process.
Old Jul 27, 2015 | 05:16 AM
Kent1999's Avatar
Kent1999
Drivers window does not need to be down. That's just a safeguard to keep you from getting locked out.
This isn't a Canadian vehicle by any chance, is it? Canadian C6's can't do the long reprogram by the owner -- only the dealer.
To Key fob help. Desperate
Old Aug 4, 2015 | 11:14 PM
Buddyleerc51
Cruising
Ok. Ready to puke now
Ordered new fob. Installed new fob battery with voltage at 3.2 vdc
Started procedure. 5 turns of key. Looking to begin programming
When I press lower half of ignition button, it tries to begin 10 minute programming sequence but quickly reverts back to "no fob detected"
New fob. New battery. Charged car battery
At wits end.
Old Aug 4, 2015 | 11:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Where is the fob during this step?
Old Aug 5, 2015 | 06:35 AM
Buddyleerc51
Cruising
I've tried it on dash. On console. In glove box slot. On my lap. No luck
