08 corvette no key help
Old Aug 6, 2015 | 03:08 PM
ChevyDave's Avatar
ChevyDave
Originally Posted by Martyn
Well my car arrives tomorrow, I have the key cut and blank FOB in hand so my worry right now is the car is on the top front of an 18 wheeler car transport truck, how can I get over the steering lock assuming it has one? and I may need to pull it from the rear to get it off the trailer assuming I can overcome the steering lock (if it has one) where would you recommend pulling it from?
Slightly worried right now
well, if they got it up there, it will come down MUCH easier.
Old Aug 6, 2015 | 03:32 PM
Martyn's Avatar
Martyn
No Dave we used a huge forklift truck to put it up there
Old Aug 6, 2015 | 04:05 PM
EVRose's Avatar
EVRose
If its an 08 there is no steering lock.
Old Aug 6, 2015 | 05:04 PM
Martyn's Avatar
Martyn
Thats what I had hoped and prayed the latest model vette I have had was an 06 this is newer and as its not here with me but on the truck on the way didnt know,, I feel a little stoopid asking but THANK YOU for putting my mind at rest phewwww
Old Aug 6, 2015 | 05:31 PM
EVRose's Avatar
EVRose
06 didn't have steering wheel lock either. I think only 05 with M6 had it.
Old Aug 6, 2015 | 06:19 PM
Martyn's Avatar
Martyn
My yellow 96 was an 05 but 06 on the title which would explain that
I am so relived to know it has no lock,, thanks for letting me know
Old Aug 6, 2015 | 07:49 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Just confirming '05 M6 does have a steering lock. Bypassed mine before it gave me problems.
Old Aug 7, 2015 | 07:42 AM
Martyn's Avatar
Martyn
Yes I hear ya, I have an 03 Anniversary edition and 02, I have done the bypass as I had problems with the 02 however I also have a Tech2 and plan to set the speed limit from 2 to 200mph hahaha when ever I get time to play with it,, for now my excitement is getting my 08 this morning
Thanks for your input
Old Aug 7, 2015 | 10:44 AM
EVRose's Avatar
EVRose
Old Aug 7, 2015 | 04:35 PM
Martyn's Avatar
Martyn
Well got my car,, it needs a good bath,, 1st thing the battery was scrap, soon got a replacement,, BCM cleansed and put back,, found the original FOB and changed the battery in it (never expected that) Pushed the button,, started right up,, no warning lights and good oil pressure
only thing is the seats do not operate correctly and the HVAC display (LCD) is out
Drives well,, just thought I would do this update and thanks for the handful who put my mind at rest with this 08 model
Old Aug 10, 2015 | 04:51 AM
Grimlock13's Avatar
Grimlock13
Did you push the **** on the drivers side on the HVAC in, to try and turn it on?
Just a thought because if you push the **** in it turns the HVAC off and you will have a blank screen. Push it again and it turns on. Took me about a month to figure that out.
Old Aug 10, 2015 | 07:47 AM
Martyn's Avatar
Martyn
Ha,, never thought of that however just went and tried and and no,, the back light comes on but there is no digits, I have tapped the screen and nothing so I have a dead display, no biggie really for me at this time,, the seat issue not moving back and forward is more of an issue for me right now as I cant get to the bolts to take the seats out to fix the driver seat module,, that's likely to be my next post Thanks for your input, very much appreciated
