07 base torque tube question
Old Aug 6, 2015 | 02:49 PM
steelfox's Avatar
steelfox
Default 07 base torque tube question
Hey all been searching for an answer for the power limit of a stock torque tube on a 07 base m6 and haven't really found anything tangible. Any help would be greatly appreciated. A little background on my vette:
I'm building a 402 and looking for about 530rwhp. Just wondering if I could leave the stock one in there or if I could upgrade to a z06 shaft if that even is an upgrade.
Thanks in advance.
Old Aug 6, 2015 | 02:51 PM
steelfox's Avatar
steelfox
The car is not and will not be drag raced. It is driven almost daily and I autocross often but that's it as far as abuse to the car.
Old Aug 6, 2015 | 07:34 PM
rpmextra's Avatar
rpmextra
My friend Peter just snapped his at the transmission. Stock LS3, GM Hotcam and that's it. He has over 1000 passes at the track and hotlaps it like a diesel.
It's the law of averages and it you do something enough it will brake. I think you'd be more than fine on the street. I wouldn't worry about it. Replacing something you may never break seems like a lot of work for maybe.
Old Aug 6, 2015 | 07:58 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Highly doubt you'll have problems.
Tons of people running over that with blowers and running the stock drive shaft.
I'd make sure your couplers/bearings are in good shape if you do have it out. I can get you the non-GM part numbers on the bearings if you do decide to replace them.
Old Aug 6, 2015 | 11:12 PM
steelfox's Avatar
steelfox
Just the reassurance I needed thanks guys!
Old Aug 6, 2015 | 11:13 PM
rpmextra's Avatar
rpmextra
To 07 base torque tube question
