2006 Lean out issue
Old Aug 13, 2015 | 09:14 PM
UmX's Avatar
UmX
Bank 1 o2 read 5.4 ohms driver side
Bank 2 o2 read 5.9 ohms pass side
Should I test the harness coming from the car to see if there's a issues there and what would I tap into there to fund that answer
Old Aug 14, 2015 | 03:21 AM
stroked383z28's Avatar
stroked383z28
Check to make sure you have 12 volts on both pink wires with the ignition on. You really need a scope to check the control side of the heater circuit, but you can get by with the following. With the sensor plugged in and the car off/ignition on you want to see 12 volts on the heater ground wire (gray/white or light green depending on which side you are checking). When you turn the car on you want to see the heater ground read either 0 volts or some value less than 12 volts. If the computer runs the heater circuit at 100% duty cycle you will see 0 volts, if the computer runs the heater circuit at 50% duty cyle you will see somewhere around 6 volts because your meter will be reading an average of the on/off voltage. What you don't want to see is that it stays at 12 volts. It may take a little bit for the computer to turn the heater on after you start the car so give it a minute.
Old Aug 14, 2015 | 10:08 AM
UmX's Avatar
UmX
after checking voltage on the pink lines i found out, some where along the line the o2 fuse got popped.. why there is a fuse is stupid but its fixed now.. thanks for all the help
Old Aug 14, 2015 | 10:14 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Everything needs a fuse.
