Shift light needed!
Old Aug 15, 2015 | 06:04 PM
Slp0327's Avatar
Slp0327
Default Shift light needed!
Hey guys....I've got a boosted GS and thinking of getting a shift light...what are you guys using?
Thanks for info.
Old Aug 15, 2015 | 06:33 PM
timd38's Avatar
timd38
I have an SLP dash pod with and Autometer gauge/light.
http://www.jegs.com/i/Auto+Meter/105...FQiDaQodaaUDJQ
http://www.coloradospeed.com/images/slp/SLP90540A.jpg
Old Aug 15, 2015 | 07:25 PM
Tropicana's Avatar
Tropicana
I love my Shift-I shift light although I confess I haven't installed it in my Vette yet because I still need more info on where to find a tach signal and I still need to take everything apart to install my audio. It has come with me from a couple other cars I owned before and is a great, progressive-style light as well as a couple other features like battery meter on startup and ability to dim itself at night.
https://ecliptech.com.au/
Old Aug 16, 2015 | 05:51 AM
The Bus's Avatar
The Bus
timd38
Was it a plug in or require cutting and soldering????
Old Aug 16, 2015 | 07:06 AM
timd38's Avatar
timd38
Originally Posted by The Bus
timd38
I had to run a wires to the fuse box for the hot and and ground and one wire to a wire in the dash for the signal. I over killed a little. I have a GM PAC-connetor kit, so I connected it to the wires on the instrument and then ran the wires to the various locations. The pod tapes to the dash, no cutting and I ran the wires behind the dash panel.
Old Aug 16, 2015 | 02:53 PM
Z06Ronald's Avatar
Z06Ronald
Thanks for info.
I bought an MSD digital shift light (part # 8963) from Summit Racing.
Old Aug 30, 2015 | 01:29 PM
spaulsen's Avatar
spaulsen
Ok guys. I need info on where to get the tach signal for the shift light. i would rather not cut/splice any wires. Wiring is not my best skill but I can do some things. Any info is much appreciated. 2007 C6
To Shift light needed!
