modified c6 state emissions
Old Aug 19, 2015 | 01:13 PM
sccaGT1racer's Avatar
sccaGT1racer
Default modified c6 state emissions
What are you guys doing about state inspections and emissions testing on your street cars with cams,headers,head work,tuners,etc?
The state of conn wants to see the cats and inspects for pass codes. That would mean swapping everything back every 2 years.
I don't want to turn my c6 into a trailer queen but would like more power.
Old Aug 19, 2015 | 04:16 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Emissions ready codes are easy to make happen in HP Tuners on any setup.
Can't help on wanting to see cats though since I still have mine.
Old Aug 19, 2015 | 04:17 PM
MARSC6's Avatar
MARSC6
Is the location doing the inspection run by the state or privately owned? In PA the inspections are done at privately owned garages and if you know the right one they may just look the other way.
Old Aug 19, 2015 | 04:26 PM
Guard Dad's Avatar
Guard Dad
Some mild cams and heads will pass the emissions test although changing the cam, heads and doing a tune might be a violation, I doubt anyone would spot it if the exhaust is clean. Headers and moved or removed cats are a red flag issue and can cost big bucks if spotted by the wrong (right?) folks. Some states are more strict than others. Headers and no cats is asking for trouble here in California. You have the same standards as California but I have no idea how strictly your laws are enforced.
Old Aug 19, 2015 | 06:00 PM
HOXXOH's Avatar
HOXXOH
The key word is "see".
Does that mean visually see the physical cats, see computer printouts of probed tailpipe emissions, or just see that no engine codes exist through the OBDII port?
Old Aug 19, 2015 | 08:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd be curious to know what is required there too. In my state they require to visually see that catalytic converters are installed. I ASSUME they want you to have the factory original cats, but I do not know that as fact.
I would suspect most states have similar requirements.
When they plug into the OBD port they are typically checking for emissions readiness checks. The inspection equipment relies on the cars computers answers on whether it believes all emissions related items are working as expected. Some states allow up to one system to be "not ready" and still allow you to pass.
It's important to note that engine codes and emissions readiness checks are two totally (although somewhat related of course) things. I'd guess the emissions equipment looks for codes as well.
Basically the computer runs through a series of checks to make sure all the emissions equipment is working correctly. i.e. pre cat O2's and post cat O2's are responding as expected (post cat O2's will cycle differently than the pre cat ones if the cats are working properly). It checks that the EVAP system is sealed properly, etc.
There is a way in HP Tuners to make the ECM basically not check any of these things and go straight to "all emissions checks are good", which will have no problem passing an inspection when they plug into the OBD port.
Here's a good explanation of one of the checks, for anyone curious. Credit to Greg Banish / Injector Dynamics
http://injectordynamics.com/articles/shelby-gt500/
6/9/2012:
Catalyst monitor diagnostic operation explained in 3 minutes by Greg Banish of Calibrated Success.
In order to explain this best, we need to look at raw O2 voltage signals both before and after the catalyst. The front O2s should be switching pretty rapidly as we toggle around stoichiometric mixture at idle and cruise. The downstream O2 signal should be much smoother. This is because a working catalyst is actually a sponge for oxygen, damping the release rate of oxygen to the downstream exhaust and O2 sensor. There will still be switching of the rear O2 sensor, but at a frequency that is much lower than that of the front.
The Catalyst diagnostic is looking at the ratio of front switches versus rear switches (or vice-versa, depending on how they wrote the code) and coming up with some ratio. If this ratio is 1:1, then the rear O2 is moving exactly as the front and the catalyst isn’t doing anything: FAILED TEST! If the rear O2 is switching, but at a frequency much less than the front, the catalyst must be acting like the proper O2 sponge that it’s designed to be: PASSED TEST! Somewhere in the three-year development process for that engine and vehicle calibration, the closed loop diagnostic calibrator came up with the right value for this switching ratio that matches “good” emissions and properly lights the MIL in the event of a non-working catalyst and “bad” emissions.
So what does this mean when you’re getting the magical scan for the DMV? They just have to plug into the OBDII port and query the test history to find out whether your catalyst is leading to the right switching ratio between upstream and downstream sensors and they can determine the health of your catalyst without ever even putting the car on a hoist or emission sampler. The OBDII diagnostics are already keeping track of that for them.
Old Aug 19, 2015 | 11:11 PM
Mike's LS3's Avatar
Mike's LS3
6/9/2012:
Yes, all the above. Same here in CA, Emissions testing checks for readiness codes using the OBD for proper function. In CA, we are allowed to have one code incomplete. Also, visual inspection of PCV valves correctly routed and exhaust system with catalytic converters in proper locations.
I have an A&A supercharger kit that is CARB certified and passed smog here in CA. The smog ****'s measured my S/C pulley, HB, check the PCV routing and entire exhaust system. I had one readiness code incomplete and passed with no problem.
Another smog **** emissions station used a mirror with a long handle to check my Chevy Silverado work truck all stock. It looked like I was at a check point in Afghanistan checking for IED's.
Old Aug 20, 2015 | 06:52 AM
sccaGT1racer
Yes they do a visual on the cats but they plug into the obd port and it must have no codes stored or active in memory. That info is transferred to the state from the privately owned inspection station.
Old Aug 20, 2015 | 03:10 PM
HOXXOH's Avatar
HOXXOH
Legally, you can't eliminate, modify, or use any unapproved aftermarket parts of the emission system by federal law. So what I'm saying is for off-road use that would also possibly pass the inspection station.
In the tune, as already noted previously, is the capability to bypass OBDII code output. So that means headers with cats, don't need a tune change, or the alternative is gut the cats and change the tune, because either way they need to visually exist. Another route is using catted headers that have an available cat delete off-road pipe that can be swapped in and out. The third choice would be checking the requirements in neighboring states and changing mailing addresses and auto registrations.
To modified c6 state emissions
