Axle back install with NPP
Old Aug 21, 2015 | 01:01 PM
Tennis_pr0's Avatar
Tennis_pr0
Default Axle back install with NPP
So I have the NPP exhaust on my corvette. My questions isn't how to remove and install the new exhaust I have coming (BB Bullets) but if there is anything special I need to do because I have the NPP system. Once I have the bullets installed, do I need to remove the fuse for the NPP? Also is there a valve or solenoid that I need to remove since I will no longer be needing the vacuum that is used to activate the flaps? So basically anything I need to know about installing an exhaust on a car that has the NPP Exhaust?
Old Aug 21, 2015 | 03:57 PM
tennblkc6's Avatar
tennblkc6
the only thing I think you need to do is cap off the vacuum hoses where they connected to the actuators.
Old Aug 21, 2015 | 04:27 PM
Tennis_pr0's Avatar
Tennis_pr0
Wouldn't it make more sense not to have that circuit alive if it's not being used though? Taking out the vacuum likes and pulling the fuse or just pulling the fuse would make more sense to me. Can some people that have replaced their NPP exhaust with an axle back or cat back chime in here? Thanks.
Also on a side note, I will be selling my factory NPP exhaust that only has 3k miles on it. Will that sell for anything on here?
Old Aug 21, 2015 | 06:09 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You should cap the lines so you don't have a vacuum leak.
They will sell for sure, but they are hard and expensive to ship so you will have better luck selling locally.
If I was you, I'd keep them for a while to ensure you like those Bullets, and, consider your future mods before selling. I had Borla Stingers, they were awesome when I had manifolds and factory cats...ok when I went with headers & aftermarket cats, a bit loud, but ok. But when I installed a big cam, it was just obnoxiously loud all the time. It was fun at the drag strip or car show but horrible in traffic. People looked at me at stop lights like my car was broken.
On my c6 I went with cutouts (before NPP's came out) and stock mufflers so I can be loud or quiet, my choice.
Old Aug 21, 2015 | 06:31 PM
Tennis_pr0's Avatar
Tennis_pr0
Pulling the fuze won't stop the vacuum from happening?
Old Aug 21, 2015 | 07:03 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I think it sets a check engine light depending on year. Check and see.
Old Aug 21, 2015 | 11:42 PM
rpmextra's Avatar
rpmextra
The vacuum comes from the back of the intake which is a pain to get to. My borla's come with a push insert that you cap the lines off at the rear when you remove them. That's all you do. I'm sure your came with them too. They kinda look like mini push pins
Enjoy the new music
Old Aug 22, 2015 | 08:26 AM
donZ's Avatar
donZ
Where are you located ?
Old Aug 22, 2015 | 08:55 AM
Tennis_pr0's Avatar
Tennis_pr0
I'm located in PA but am willing to sell and ship my NPP at a very good price if you are interested.
Old Aug 22, 2015 | 12:41 PM
ssmike56's Avatar
ssmike56
I sent a PM inquiring about the NPP's
Old Aug 24, 2015 | 03:52 PM
C6David's Avatar
C6David
I put some corsas on my npp equipped car. All I did was cap the vacuum lines and pull the fuse. No issues what so ever.
To Axle back install with NPP
