Installing new ring and pinion. speedo sensor question
Old Sep 7, 2015 | 01:53 PM
dentalfloss's Avatar
dentalfloss
Default Installing new ring and pinion. speedo sensor question
Hello. I am in the process of installing a Motive ring and pinion in my 2006 M6 differential. This is going in my 2005 C6 coupe. In my 2005 diff the ring gear has cogs that line up with the speedo sensor in the hole. Now this 2006 diff I bought does not have these cogs on the original ring gear and the speedo sensor lines up with the teeth. When I ordered the new Motive gears, they have the cogs. So I am guessing the 2006 diff sensor read off the teeth. Is this so? Seems weird to me. I hope I made sense.
Old Sep 7, 2015 | 02:06 PM
timd38's Avatar
timd38
That would be my bet. Don't forget to re-calibrate the speedo after the gear change.
Old Sep 7, 2015 | 02:40 PM
dentalfloss
There is no need to recalibrate your speedo on a manual trans. car after a gear swap.
Old Sep 7, 2015 | 02:44 PM
timd38's Avatar
timd38
Maybe not on an 05, but I almost positive on an 06 or newer. 05 has a different computer than an 06. When I went from 3:42 to 3:73 they told me they had to do it, but it was a few years ago, so I may be mistaken.
Old Sep 7, 2015 | 08:13 PM
Boomer111's Avatar
Boomer111
No calibration was needed on my 08 MN6 going to 4:10 diff.
Old Sep 7, 2015 | 08:28 PM
timd38's Avatar
timd38
So how does it know that the gear ratio changed and adjust accordingly? Not a statement, but a question. Does it use the wheel sensors?
See post #5 from RPM.
https://www.corvetteforum.com/forums...ear-gears.html
Old Sep 8, 2015 | 08:18 AM
Boomer111's Avatar
Boomer111
https://www.corvetteforum.com/forums...orrection.html
See post #7 by Joe G.
Old Sep 8, 2015 | 08:47 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Autos must have their tunes changed when gear ratios change as the transmission shift points are based on rpm and speed and those ratios change, obviously, when the gear ratio changes. C5's and 05 C6's with reluctor wheels don't need to change the tune in a manual car when the gears are changed.
Dentalfloss I've been racking my brains to remember if there is any problem going from the 05 with a reluctor to later with no reluctor. This goes back a long time and I"m not 100% positive but I THINK you do need to change your VSS pulses per mile when going from the 05 with the reluctor to the new diff that reads VSS pulses off the ring gear. Obviously there are a lot more pulses on the ring gear than the reluctor per mile.
You can verify what I'm saying by looking at a stock 05 tune for VSS pulses and then an 06. If my memory is right, I'd copy the 06 VSS per mile as a start, then, use a speedometer app on your phone to fine tune your speedometer by adjusting the VSS pulses per mile.
Old Sep 8, 2015 | 09:23 AM
timd38's Avatar
timd38
Thanks!
Not sure what is correct.
I called the guy that put mine in and he said that every 06 to 12 Corvette that they have put gears into, had to have the speedo calibrated.
Old Sep 8, 2015 | 06:10 PM
dentalfloss
Yes I bought a trans extension housing that will allow me to install the 06> diff. I thank you very much for your response. So what you are saying is that my speedometer will work but may not be correct. I know the speedo sensor on my 05 and the one on the 06 are the same part number. I quess I will find out after the install and then take it from there. Again thank you.
Old Sep 8, 2015 | 06:43 PM
Boomer111's Avatar
Boomer111
Thanks!
Well I did not do the work and it was 7 yrs ago. As I remember though I was told nothing had to be done, I know I did not pay for anything is this regard and I was concerned and asked. Also as I recall my search led to the same conclusion.
As always I could be wrong.
Funny thing is I remember chasing this question 7 years ago and got mixed answers then too. My shop said nothing needed to be changed, not sure if this included anything in the tune but as I understand nothing in the way of a part change. I recall now that DTE Engineering told me the same thing prior to purchasing their complete rebuilt differential.
Old Sep 8, 2015 | 08:07 PM
ColtaBilly's Avatar
ColtaBilly
I put in a RPM 3:92 diff in my 05 M6. Speedo is off by 5 mph, I tried calibrating with my Predator...no real change. I live with the 5 over.
Old Sep 8, 2015 | 08:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I just looked at a stock 05 vs stock 06 file and the VSS pulses per rev. are almost the same (40 vs 41)
Pulses per mile under "PCM output calibration" were 30,828 and 31,599 for 05/06 respectively
"VSS tire revs per dist" were identical at 479 per km
To Installing new ring and pinion. speedo sensor question
