Base c6 upgrades
http://www.tirerack.com/tires/tires....ling%20Package
they will get me to 1.05g? and to be clear is the swaybar getting me any g's or is it just to control body roll? the super sports, will they all0w me to get to 60 in 3.8sec with the headers and tune or will i need more. and out of curiosity, is it impossible to get 3.8 sec on the stock tires or will i just need a lot of power?
You'd likely never achieve 3.8 0-60 with those Goodyear runflats. It would take some serious skill and I don't know you so maybe you could. But you can launch much more aggressively with a grippier sticky tire and That would help you better achieve that goal. A little more power like headers, intake tune will make sure it capable and then you got to do the rest.
I've achieved a 0-60 in 2.48 seconds but let's not forget that's at a well prepped track and hoosier drag radials on.
So 3.8 on super sport runflats with headers, intake, tune, and a little practice?
Now because you have somewhat of a fear of having a flat and also of spending money, I suggest you should just forget the 1.05 G for now and spend a lot of time practicing your launch technique. Once you master the straight ahead driving, then make some mods and revisit the skidpad. You'll learn more in the process of tearing up the current tires, than you will with good ones that'd hide your shortcomings.
The sway bar and shock upgrade is a good idea but I would first start with the best and widest tire you can fit under the fenders. The Re11 is a great dual purpose tire. Stop worrying about flat tires if you want performance. You have tpms to tell you if a tire is getting low. Don't forget to setup your alignment for performance.
OP you seem so eager to gain g's yet you keep trying to do so with your oem tires. we are trying to put a nail in with a screw driver. What you need is a hammer.
Tires will be the single most effective upgrade to your current set-up. I don't know how or why you come up with a wanted "g" but you can't get there without a great tire. I would suggest before all things. Get a great tire and try that first before anything else. Every other upgrade is pointless if the car can't grip the road.
Also, it's hard and next to impossible to guess what part will give you what g gain. but it's a fact that tires, for you're money will bring you the most over those RF Goodyears. 0-60 times will drop, and lateral g's will rise with a good set of tires. no other mod will affect both of your needs as well as tires will. power will only give you acceleration, suspension will typically only help cornering but tires can do both.
Food for thought
2008 Z06 (Goodyear Eagle F1) 0.97g
2011 Z06 (Michelin Pilot Sports P2) 1.08g
2012 Z06 (Michelin Pilot Sport Cup) 1.13g
Out of curiosity on my behalf, can I ask you why g's are so important. Are you ever going to test this theory to prove outcome? Are you competing in something?
Food for thought
If I could be bold and tell you what to do, I say get your car out there as is, and then start to figure out what you're missing, or what you think your missing first.
Big brakes maybe, I'd even think a track tire/rim combo only for the track like hoosier A7's or something....but more important, and for fun. get out on the track and see. only then could you ever really appreciate your gains as you add them.
Corvettes require a driver, they are a skilled mans car. Even with straight line performance it takes great skill to harness their potential. I just started drag racing my car this summer, got hooked badly.
first night out thought id run a 10.xx since I came swinging with a LS7 stage 3 head cam package and a set of slicks. went home humbled with a 11.77 @ 127mph.......been at it all summer and with the very same car and build, currently bested at 10.57 @ 136.5mph and still have lots of room to improve.
if you're anything like me, and just kinda getting started, the car is more car than you probably are driver. Have fun, and get on the track asap.
Or these:
http://www.michelinman.com/US/en/tir...per-sport.html
I cant afford cup tires so it will have to be one of these. Im hoping the pilot super sports are better because they are cheaper.
Or these:
And I'd add that the best first money spent would be for skill upgrades at either Bondurant or Spring Mountain.
I almost fell off my chair hahaha. I never even noticed we had that one.
