Help! P2135 issue
Old Sep 16, 2015 | 04:38 PM
Moose_44's Avatar
Moose_44
Default Help! P2135 issue
Having issue with p2135. Replace TB with oem part as TB was bad when tested. Worked for 3 days now back to reduced power mode. Days of searching car found when clutch pushed in neutral safety switch engaged, TPS 1 gets a .6 volt power surge for a split second. TPS 2 is not affected so the car throws code and reduced power. If u clear and push clutch a coulple more times surge goes away. Let it sit for a few minutes and surge comes back. Replaced neutral safety switch and no change. Anyone have this issue? Anyone know where these two sensors interact with each other? ECM issue? Car is a 07 base with headers, corsa, FAST 102, haltech CAI and HP tune.
Thanks.
Old Sep 16, 2015 | 07:51 PM
rpmextra's Avatar
rpmextra
what year
Old Sep 16, 2015 | 08:16 PM
Moose_44's Avatar
Moose_44
2007 6.0 ls2.
Old Sep 16, 2015 | 08:23 PM
rpmextra's Avatar
rpmextra
1. Wiggle tug test the wire harness at the throttle body while checking the Agree/Disagree data value on the scanner.
2. Work the APP sensor back and forth at the same time and hold in different position while looking for a glitch.
Look at t your TB connector very closely. that would be where I'd put my money
Old Sep 17, 2015 | 02:00 PM
Moose_44's Avatar
Moose_44
Thanks for the info. We swapped out the pigtail on the connector and no luck.
Old Sep 17, 2015 | 02:42 PM
rpmextra's Avatar
rpmextra
That's the #1 issue with confirmed fix I know with those codes. Do you by any chance have another TB lying around.
Old Sep 17, 2015 | 02:48 PM
Moose_44's Avatar
Moose_44
We just put a new on on. The old was was tested and had a bad TPS sensor.
Old Sep 17, 2015 | 02:49 PM
Moose_44's Avatar
Moose_44
I am leaning to PCM as it seems it's the only place the clutch sensor and TPS sensors cross paths.
Old Sep 17, 2015 | 08:12 PM
rpmextra's Avatar
rpmextra
is there a progressive clutch pedal in those years? have u tried a clutch position relearn if so?
Old Sep 18, 2015 | 04:10 AM
Moose_44's Avatar
Moose_44
Default Answer
I am not sure. I will check with my tuner. Thx.
Old Sep 21, 2015 | 09:58 PM
Moose_44's Avatar
Moose_44
Update: 25 plus hours tracking down wires and found a short in the main wire harness for the car coming out of the BCM. Fixed the short ( replaced wires, not entire harness) and all is back to normal. What a nightmare this was. Put a couple hundred miles on car and all seems normal. No more power surges or clutch pedal issues.
Old Sep 21, 2015 | 10:28 PM
rpmextra's Avatar
rpmextra
well so wire/pigtail was in a way the issue. man real bummer working 25+ hours hunting that down. Thanks for updating
To Help! P2135 issue
