Has anyone tried to install a set of C7Z mufflers on a C6Z? My friend has a C7Z and that car has the best sound I've ever heard on a stock car. I'm just wondering if the sound would transfer over if I put a set on my car.
i dont think its the C7 mufflers that make it sound good is the LT4 in the C7Z, i have 2012 ZR1 mufflers on my 06 Z06 and it sounds great, and its on a switch ( mild to wild kind, home made version )
Different geometry. However with enough cutting, hacking, welding, cussing, and massaging with a big f'ing hammer just about anything is possible.
I don't think the means would justify the end. May want to look at aftermarket or pick up an x-pipe (assuming you have h-pipe) and the later model C6Z mufflers that were carried over from the ZR1 in 2011 I believe. Many say the 2011+ mufflers and x-pipe sound the best of all years.
