blown ls3, what to do now
Old Sep 27, 2015 | 09:43 AM
donb1226's Avatar
donb1226
Default blown ls3, what to do now
i know have a hole in the side of my ls3, what is my best option to go about fixing this.
it has superchager, cam, methanol, tuned to 670hp
Old Sep 27, 2015 | 09:58 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
JB Weld
Old Sep 27, 2015 | 10:53 AM
icntdrv55's Avatar
icntdrv55
I believe the correct tense is "had"...
Pretty sure there ain't no 'fixin' to be done for a hole in your block. New/rebuilt short block from a reputable engine supplier would fix it.
Old Sep 27, 2015 | 11:27 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Sorry for you, but you're in for a total rebuild. The hole in the block was caused by something else letting go....most likely a rod but could be any other engine internal part. Hopefully the top end of the engine is salvageable, but only a good engine builder can tell you that.
Old Sep 27, 2015 | 11:28 AM
Boryke's Avatar
Boryke
First thing I'd do is go about figuring out WHY you have a hole in your block. Bad tune? Weak link in the bottom end?
Old Sep 27, 2015 | 11:30 AM
Mike's LS3's Avatar
Mike's LS3
If you plan on keeping the S/C, new block with forged internals. Build a strong bottom end with a safety margin for you targeted HP.
Find out what caused the engine to go!
Maybe some forum members will recommend reputable engines builders who have gone through this experience.
Good luck!
Old Sep 27, 2015 | 12:40 PM
donb1226's Avatar
donb1226
what would be a good short or long block to go with?
it was tuned at ECS
i like the jb weld idea. maybe i will try that first
i not sure if the heads are good or not. I know I'm getting a short block atleast either way. what internals would i get and from who is the question.
Old Sep 27, 2015 | 12:42 PM
timd38's Avatar
timd38
Piston size hole or pin size hole?
Old Sep 27, 2015 | 03:50 PM
HOXXOH's Avatar
HOXXOH
Go big LSX 454
Old Sep 27, 2015 | 03:51 PM
donb1226's Avatar
donb1226
big enough to see the crank
Old Sep 27, 2015 | 03:52 PM
donb1226's Avatar
donb1226
the lsx crossed my mind but won't that cost considerably more
Old Sep 27, 2015 | 04:15 PM
timd38's Avatar
timd38
C5R blocks are great, but very pricey.
Old Sep 27, 2015 | 04:25 PM
donb1226's Avatar
donb1226
eberyone said the stock ls3 doesn't blow up ...
Old Sep 27, 2015 | 04:32 PM
timd38's Avatar
timd38
The block had impact from a connecting rod. I don't know a block that will not break when hit by a connecting rod.
Old Sep 27, 2015 | 04:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
The point being most people say the internals don't break to begin with on stock LS3's at that power level with meth. No broken internals would have = no hole in the block.
That's going to take a lot of JB Weld I don't think you can JB weld the connecting rod though (kidding, of course)
GL with the rebuild. It is unfortunate given how few of their stock engine builds supposedly let go.
Old Sep 27, 2015 | 06:29 PM
HOXXOH's Avatar
HOXXOH
Yes, but you can enjoy more power for a longer time between breakage.
I have a good crank, but my block has holes in the cylinder wall.
Old Sep 27, 2015 | 09:06 PM
highrolrcustoms's Avatar
highrolrcustoms
it was tuned at ECS
Could you give some details about mileage on engine, how many miles supercharged, babbied or driven like you stole it. Lol.
To blown ls3, what to do now
Old Sep 27, 2015 | 09:14 PM
donb1226's Avatar
donb1226
supercharged since around 3-4000miles. i drive easy a lot but do get on it hard once in a while but not for extended periods of time. more like roll on a couple gears the back to driving like a normal car.
Old Sep 28, 2015 | 12:20 AM
c6moneypit's Avatar
c6moneypit
Sorry about what happened. I just finished with my ls3 rebuild in my GS (A&a with meth and s/c cam, etc...). Mine lasted for 2 years at 630 rwhp with 8-9 psi(1 year tracking at HPDE's) until I developed a noise; lifters went bad and were making the noise and #5 cylinder had an uneven shape (smaller diameter towards the bottom) causing the piston skirt to start to collapse. Had the shop do a full engine rebuild with forged internals, lower compression, larger displacement, performance lifters, 8rib kit, etc. Unfortunately the rebuild took 8 months, and currently trouble shooting aspects of the build. The 8 rib kit had alignment issues and chewed up a belt. Now just have to upgrade my oil cooling system since the larger displacement seems to be making the car run 15 to 20 degrees hotter when not at highway speeds and when ac is on.
Just wanted to share my engine build experience. It could take a while since good builders are usually pretty backed up with orders and then there seems to be a trouble shooting period once you break the engine in. Good luck getting the engine done; hopefully you will have a much less downtime than I experienced.
Old Sep 28, 2015 | 12:56 AM
highrolrcustoms
This is what scares me about swapping to a supercharger. Im at 568rwhp/646tq on a 150 shot on ls2. Was looking to swap to a ECS kit with meth and turn it up to 700rwhp but dont wanna be blowing a engine shortly after i do it. Guess it a chance ya take. Gotta pay to play.
