Front suspension question
Old Oct 13, 2015 | 01:30 PM
Gaunai's Avatar
Gaunai
8th Gear
Default Front suspension question
Okay, I'm hoping I'm not crazy here... But shouldn't there be a nut on this? Neither side has one. Only had the car a few months. If so, what size?
Old Oct 13, 2015 | 01:33 PM
LFZ's Avatar
LFZ
If you are referring to the leaf spring adjustment stud there.....there is no nut that needs to go on that.
Old Oct 13, 2015 | 01:37 PM
Gaunai's Avatar
Gaunai
8th Gear
Ah good, I've never dealt with leaf springs before. From your wording though... Do you mean there is not one that needs to go on there? Or that there is not one needed. Lol
CMY SIX's Avatar
CMY SIX
but that doesn't mean your still not crazy, just sayin....
Old Oct 13, 2015 | 02:03 PM
LFZ's Avatar
LFZ
It didn't come with a nut from the factory. Therefore it appears as though its not needed, but if you feel the need to put one on there, then fulfill that need and throw one on....but I am pretty sure the need for one would be there from GM if they felt that it needed it.
Old Oct 13, 2015 | 03:19 PM
Sayfoo's Avatar
Sayfoo
https://www.corvetteforum.com/forums...sing-nuts.html
a little more info here
Old Oct 13, 2015 | 08:33 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Try turning the threaded portion.. you'll see real quick why a nut isn't needed
Old Oct 15, 2015 | 03:59 AM
Guard Dad's Avatar
Guard Dad
Just a word to the wise, be very careful to keep solvents and aggressive cleaners off of the leaf springs or you run the risk of spring collapse. It's in your owners manual.
Old Oct 15, 2015 | 08:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Actually, there is already a nut installed, but it's embedded in the leaf spring where you can't see it.
As others mentioned, you can read all about the ride height adjustments by using Advanced Search.
To Front suspension question
