C6 Z06 overheating again
Mods on car:
vortech v3 with A&A kit,
boost a pump
corsa exhaust.
everything else is stock.
https://www.corvetteforum.com/forums...connector.html
https://www.corvetteforum.com/forums...melt-down.html
https://www.corvetteforum.com/forums...ontroller.html
I hope this helps.
good luck
good luck
The first is the connector about half way down passenger side back of the radiator, then below that, you will see the pwm controller, and there is another connect that plugs into that as well.
So start with the top connector half way down on the back side of the radiator that you can get to from the hood side, and if it looks fine when unplugged and checked, then get under the car to disconnect the PWM controller connector to check that connector and the PWM pins for melting problems next.
This is the top one that you are checking to see if it melted,
And this is the lower PWM connector to see if it or the PWM pins are melted instead,
The loose connector in the below photo is clipped to the shroud of the radiator just above the PWM module and will be able to spot it from the top of the car just looking down.
So start with the top connector half way down on the back side of the radiator that you can get to from the hood side, and if it looks fine when unplugged and checked, then get under the car to disconnect the PWM controller connector to check it out next.
aaaaah i see what you mean now, pics are much more helpful
in case none of these connectors are burnt out or melted, what you guys suggest i do next?
From there, you can check power from the battery at the PWM connector to make sure that the PWM is getting power to begin with.
If you do have power at the PWM controller from the battery, then it comes down to either the PWM burnt up, the fan burnt up again, or a problem in the PWM control wire from the ECM.
In the above photo of the PWM, 31 is your positive from the battery, 30 is the ground to the frame, and the red wire with the blue heat shrink is the control wire from the ECM. So with a multimeter, check the PWM connector for pins 30 and 31 to make sure you have power at the pwm connector.
As for the PWM, it a pulse width modulator, so battery power in, power out to the motor on M+ and M-, and the ECM control wire will control the module output (pulse widths) to run the fan at a give speed on the M wires to the fan.
So i replaced my battery since it was bad and fan is working fine , turned it off and on couple times, seems like its working now, i will take it out tonight hopefully it keeps running.
