no start
Old Oct 25, 2015 | 11:56 AM
ERIC_MEMS1@YAHOO.COM's Avatar
Default no start
I bought a 06 C6 last year that was hit in the front , the air bag deployed . I repaired the entire car but cant get it to start. Do I need to have the srs computer or the ECM reprogrammed ? Pease help!!
Old Oct 26, 2015 | 11:20 AM
C6topless's Avatar
C6topless
someone will certainly chime in but I seem to remember a connector located on the passenger side concealed by the fender that causes a lot of no start failures after a impact.
Old Oct 26, 2015 | 12:50 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah there's quite a few connectors under the passenger side fender, near the battery. No idea if they are the problem, but I can confirm there are a lot of large connectors over there. The ECM is not far away from there also.
Old Oct 28, 2015 | 05:59 PM
Default no start
ok Thanks I also tried to bleed the clutch and now my clutch pedal is super hard .My clutch , Plate and bearing are brand new, and im pulling my hair out
Old Oct 28, 2015 | 06:30 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
How hard? As in, so hard that it won't go down? After the install did it work at all or was it hard from the beginning?
Old Oct 29, 2015 | 09:37 AM
Default no start
hard from the beginning, I could almost stand on it, it bled alittle at first but now it wont move, Im gonna take the line apart to see what I can find.
Old Oct 29, 2015 | 10:44 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You sure the connection between master/slave is on correctly? Both ends have connectors that won't let fluid flow until they're mated together
To no start
