Check engine light
Old Nov 1, 2015 | 01:05 PM
FITZVET's Avatar
FITZVET
Default Check engine light
Need some help guys.Check engine light on.Went to parts store and they pulled codes p0030,p0053,and p0442.Is this all from O2 sensors,fuse or what?Where do you start?Any help on this would be appreciated.2007 LS2 with LT headers and Hi flow cats.
Old Nov 1, 2015 | 06:58 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Google is your friend...BUt I guess ill do the leg work for ya ..I got nothing else to do...JK
https://www.corvetteforum.com/forums...ror-codes.html
https://www.corvetteforum.com/forums...030-p0053.html
https://www.corvetteforum.com/forums...ght-p0442.html
this is just a few I found, but there are so many other threads out there ,,,
Old Nov 1, 2015 | 08:09 PM
FITZVET's Avatar
FITZVET
Thanks Ptroxx,I actually googled the codes myself.I did replace gas cap a couple of days ago,but did not remove Positive cable.Will try and let you know.Appreciate your input.Thanks.
Old Nov 1, 2015 | 10:41 PM
owc6's Avatar
owc6
When putting your gas cap back on, it is helpful to just get the threads engaged and PULL on the cap to tighten. Seems counterintuitive, but it really does work.
Old Nov 2, 2015 | 04:22 AM
FITZVET's Avatar
FITZVET
Thanks,I'll try that also.Never does seem like cap seats itself.
To Check engine light
