flexfuel
Old Dec 6, 2015 | 06:50 PM
curtisb23's Avatar
curtisb23
Default flexfuel
has anyone ever wired up there own flex fuel sensor on there c6 base? yes I know dsx sells a kit but I only need the harness from his kit and he wont sell me just that . thanks
Old Dec 6, 2015 | 07:09 PM
timd38's Avatar
timd38
I got an education on E85 when I went to work for an oil company and to be frank, now that I know what is in that stuff and how inconsistent the quality of E85 is, I won't use it.
Old Dec 6, 2015 | 07:45 PM
curtisb23's Avatar
curtisb23
I like to make as much power as I can and safely so ill use it as much as I can
Old Dec 6, 2015 | 07:49 PM
curtisb23's Avatar
curtisb23
my hole point in this post is about wiring run your own ethanol sensor
Old Dec 6, 2015 | 09:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You run one pin to the ECM and supply power to the sensor. Plumb the sensor in, adjust tune to know the sensor is there and what to do based on ethanol content and there ya go.
Old Dec 6, 2015 | 10:21 PM
curtisb23's Avatar
curtisb23
give sensor v5s power correct? ground it and pin it to the ecu rite? I forget the pin number off the top of my head
Old Dec 6, 2015 | 10:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah should be 5V as far as I know. I read something about some sensors being 12V though.. hell if I know. It's one of the two
Pin # is different on different ECM's. Everything except E40's is pretty commonly known so you should be able to find it with some googling
Old Dec 6, 2015 | 10:41 PM
curtisb23's Avatar
curtisb23
yeah I have the pin number for the ecu somewhere ,I think its 5vls
Old Dec 6, 2015 | 10:43 PM
curtisb23's Avatar
curtisb23
so now .what has 5v I can use lol
Old Dec 6, 2015 | 10:46 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
MAP sensor assuming it doesn't use too much current. I run two other pressure sensors off of the MAP sensor 5V. You can get ground there too while you're at it.
Or you can get a voltage converter from radio shack. Well.. you used to could anyways. Now all they'll sell you is a cell phone plan
Old Dec 6, 2015 | 11:05 PM
curtisb23's Avatar
curtisb23
ill check that one out
Old Dec 7, 2015 | 08:29 AM
DSteck's Avatar
DSteck
The problem is my harness is meant for where my hard parts put the sensor. I have no way to know where you're putting your own sensor and can't guarantee it'd fit.
Old Dec 7, 2015 | 08:42 AM
curtisb23's Avatar
curtisb23
i dont need any guarantee on that ,i know what i need to do. the hardline isnt going to work on how i have my fueling setup. so ill make my own line . thats how i am going to do it if i wire it up my self.
Old Dec 7, 2015 | 08:47 AM
jesse82nc's Avatar
jesse82nc
I used the kit you made, worked awesome. Super easy to install and works great.
I run E85 all the time, it's also my DD. Only time I have ran E10/93 octane is when I drove the car from NC to Florida a few months back and didn't really care to search high and low for E85.
Luckily I have more than dozen Sheetz near me that carry E85, and it's always 80-85% (even right now in Dec) as checked by my Ethanol test kit and via the sensor reading in HPT. I check it with my test kit about every 2-3 weeks, and usually about once every other fill up via HPT. I paid $1.38 yesterday to fill up. I drive the car probably 250-400 miles a week, depending on the weather.
I average about 15 mpg on E85 driving around town and sitting in traffic for those 250 or so miles per week. When I can do more highway and cruising, it's closer to 19 mpg. On 93 I was getting about 19 mpg around town and 24 mpg on the highway. Mine's a Z51 A6, so take that into account for gearing in the trans.
Old Dec 7, 2015 | 08:50 AM
curtisb23's Avatar
curtisb23
do you have a pic of it installed on a c6?
Old Dec 7, 2015 | 08:52 AM
curtisb23's Avatar
curtisb23
sweet. im not saying anything bad about his kit,i just dont need some stuff out of it and asked him a question ,then i posted on here how to wire my own up
Old Dec 7, 2015 | 09:02 AM
jesse82nc's Avatar
jesse82nc
If you are pretty good at wiring, it should not be hard to make your own kit.
Here's the DSX kit on my C6.
To flexfuel
Old Dec 7, 2015 | 09:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That looks great
Old Dec 7, 2015 | 09:13 AM
curtisb23's Avatar
curtisb23
yeah i dont use the oem rail or anything i have my own feed lines and stuff
Old Dec 7, 2015 | 09:15 AM
curtisb23's Avatar
curtisb23
iv wired up my own stuff on a haltech ecu for my old car , flex fuel ,map, air intake temp an so on .just need to know where to put the wires on the c6 witvh is discussed aboved
