Pulling an LS engine with the wiring harnesses connected to the engine
Anyone ever pull an LS engine with the wiring harnesses still connected to the engine. Pulling one out of a wreck and have all the harnesses forward to the lights, back to the cabin/firewall and the fusebox loose and wrapped up in a neat package, if you can really do that.
Don't really want to remove the wiring on the engine, trans, AC, alternator and whatnot. So I thought it may just come out with the whole thing together.
There is a ground to the frame under the battery tray. Also, the trans harness is separate from the engine harness. The trans harness is zip tied to a metal bracket that is bolted to the back of the block and runs to the computer.
