Clutch question help please
Old Dec 14, 2015 | 07:23 PM
Mitchem1992's Avatar
Mitchem1992
Default Clutch question help please
So I'm going with the mantic twin clutch. Is everything there that I need to just install it? What else need to be replaced when you replace the clutch? Also do I need to buy a new tick for the master cylinder or just install a new master cylinder.
Old Dec 14, 2015 | 11:19 PM
rpmextra's Avatar
rpmextra
mantic comes with a new slave if I'm not mistaken and no you don't need to replace the master unless it is faulty. So you will be replacing, Clutch, pressure plate & flywheel along with a new slave cylinder. Are you doing the work yourself? if so here is a pretty good but DYI some guy on the forum wrote
https://www.corvetteforum.com/forums...full-pics.html
Old Dec 15, 2015 | 11:48 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Depends where you purchase it from, we also include a clutch bleeder kit and a pilot bearing along with shipping in the cont US.
Then we feel you have everything you need to do a start to finish install.
I would also recommend using the stock master in our experience.
To Clutch question help please
