Just bought a set of kooks headers with off road x pipe. Just wondering what you guys do for that 02 sensor. I know you can just use the downstream 02 sensor already on the car, but I don't want it just dangling there. I would also rather not cut it. Do you guys just tuck it away somewhere or is here a plug/bolt I can use?
Rear O2 ports get pluged in the X pipe, the rear O2's sensors get unplugged from the cables/cables tied up out of the way, and the rear O2 sensors get turned off in the tune.
Hence without a working cat, there will not be enough of a differential reading between the pre and post O2 sensors, and with both in play, will end up throwing codes.
Hell, even with high flow cats since they are less effective than the OEM cats, the rear O2's still get pulled and turned off in the tune.
Really, all the rear O2's are doing it telling the ECM how effective the cat's are preforming only. So the ECM is using the pre O2's for the needed adjustments, and the rear/post O2"s are just checking to make sure that the cats are doing there job to reduce the emissions more.
Cool thanks guys. I actually found some at advanced auto for like 10 bucks a plug. I'm just gonna do that so it will look neat instead of the wire sitting there for no reason.
Thanks guys, just ordered two of these. 3.50 each. I figure it will be a lot neater to just plug the hole with those rather than have to tuck the sensor wires out of the way.
