aux input issue
Old Dec 23, 2015 | 06:51 PM
MJC611's Avatar
MJC611
Default aux input issue
In '09 vert when playing music from phone through the aux input, the voice part of the music comes through very weakly while the instrumental part is at normal volume. Have tried cleaning jacks and plugs on both ends but no help. The phone plays music fine through earbuds and home stereo. Have tried two different cords with same result. Any thoughts?
Old Dec 24, 2015 | 09:10 AM
Vettes R Us's Avatar
Vettes R Us
St. Jude Donor '12
Check your stereos EQ settings. You may be on a setting that is not conducive to bring the voice out.
Old Dec 24, 2015 | 10:24 PM
MJC611's Avatar
MJC611
CD's and radio sound normal. I'm wondering if most of the vocals on recordings are on one of the stereo channels and the contact for that channel is not making a good connection/is loose. Don't know enough about how recordings are made to know if this is a possibility.
Old Dec 25, 2015 | 04:38 PM
Vettes R Us
St. Jude Donor '12
Have you checked the aux cable to ensure it was stereo and not mono?
Old Dec 25, 2015 | 08:29 PM
Dcasole's Avatar
Dcasole
Or that something is not wrong with the cable ...
Dave
Old Dec 25, 2015 | 08:39 PM
MJC611's Avatar
MJC611
The cables are the same ones used when the aux input worked properly a couple months ago. I'm thinking the problem must be a broken wire that connects to one of the contacts in the jack or poor jack/plug contact in spite of the cleanings.
Old Dec 26, 2015 | 06:31 AM
Dcasole's Avatar
Dcasole
I still would check the cable ....the are inexpensive to buy and are the highest wear point in the system . Sounds like you lost a system ground wire .
To aux input issue
