Steering Position Sensor
Old Dec 30, 2015 | 05:34 PM
fasttz06's Avatar
fasttz06
Default Steering Position Sensor
Hi all,
I did cam/lifters swap on my 2010 GS Corvette a while back. When the steering rack was disconnected, I did turn the steering wheel many turns, more than 4. I did not know I'm not supposed to do that.
Now I have the "active handling" and "service traction control" warnings. The car goes into limp mode and I can't disable the traction control. My airbag light is always on and my horn is not working.
I know I broke the clock spring. I ordered a new one and I'm going to replace it as soon as I get it. But what about the steering position sensor? Do I need to replace it? I heard that the steering position sensor can be calibrated or centered with Tech 2. Can anyone confirm?
Old Dec 30, 2015 | 07:33 PM
ErnieN85's Avatar
ErnieN85
Originally Posted by Kafood
Hi all,
Yes it can be done with a TechII
Old Dec 30, 2015 | 08:11 PM
fasttz06's Avatar
fasttz06
Great. Thank You!
Old Dec 31, 2015 | 12:30 AM
whit1's Avatar
whit1
U probably broke the sensor. When I took the steering rack out doing my cam. The sensor broke giving me the same issue u had above. Once we replaced the sensor all was fine.
Old Dec 31, 2015 | 04:15 AM
fasttz06's Avatar
fasttz06
Thanks for the input. How did you know the sensor is broken? Did you try to calibrate the sensor with TechII before replacing it with a new one?
Old Dec 31, 2015 | 12:57 PM
Dano523's Avatar
Dano523
read post 11,
https://www.corvetteforum.com/forums...djustment.html
To Steering Position Sensor
