Halltech 103 intake for LS7
Old Jan 1, 2016 | 11:10 PM
JadAzzam21's Avatar
JadAzzam21
Default Halltech 103 intake for LS7
anybody have anything to say about it?
Old Jan 1, 2016 | 11:48 PM
djbrun's Avatar
djbrun
I can tell you that it is much more MAF friendly that the killer bee II.
With the killer bee I had turbulence across the maf resulting in a rough idle and surging. With the mf103 all that went away.
It is not a true CAI since it does not draw in cold air.
DJ
Old Jan 1, 2016 | 11:58 PM
JadAzzam21's Avatar
JadAzzam21
Would a tune be required? All I have are headers and full exhaust
Old Jan 2, 2016 | 10:24 AM
G2theMFNP-C6Z51's Avatar
G2theMFNP-C6Z51
6th Gear
Default Halltech Intake
I will run without issue no tune, but a big change in intake volume like the Halltech system provides will benefit from a good tune. Jim Halltech is well respected and states with a tune this intake will pick up 31HP.
I installed this intake on a 2010 Z and the customer told me within 50 miles of driving he could feel a SOTP difference, especially in the mid range (3400-4900). He moved to Florida and had in tuned there. No track times, but stated he ran a buddy with a 2011 that was stock and put 3 full car lengths on him from a 30mph roll after the intake/tune. Before they were about dead even.
General rule of thumb is 10HP is a car length (before/after same car). But there are a lot of variables in any given situation, so each car will respond differently and tuner skills vary as well.
Old Jan 2, 2016 | 12:26 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
A 103 with a VetteAir and a tune would be killer.
Old Jan 2, 2016 | 12:48 PM
Mike's LS3's Avatar
Mike's LS3
Why spend the money on an air intake and headers without a tune? Maximize your mods with a tune.
The MF 103 with the Beehive Shroud is a good choice. It works well keeping the IAT's temps down and idle quality is good.
Old Jan 2, 2016 | 01:07 PM
djbrun's Avatar
djbrun
Stock air intake is fine, there is no horsepower in an aftermarket intake With no shroud mods to make it a true CAI.
Putting a beehive over a stock intake would be equal.
The Z picks up good power on a tune alone.
DJ
timd38's Avatar
timd38
I have one on my stroked LS3 and would buy again. First class quality!
Old Jan 2, 2016 | 02:49 PM
JadAzzam21's Avatar
JadAzzam21
And is it necessary to keep the heat shield that it comes with installed?
Old Jan 2, 2016 | 03:10 PM
dmoneychris's Avatar
dmoneychris
I have the Halltech MF103 for my 2013 Grand Sport. It's pretty neat that it comes with the heat shield that separates the hot air from the engine compartment from the air intake. It seems like it's working really well. The car has the Halltech MF103 CAI, the LT's, X-pipe & full exhaust. It put down 435 LBFT TQ to the wheels w/those parts & a tune of course. I added the Halltech at the same time I got the headers & exhaust.
Old Jan 2, 2016 | 06:08 PM
Mike's LS3's Avatar
Mike's LS3
The benefit of the shroud is to prevent warm or hot engine air entering into the engine through the air filter. Once intake air temperature (IAT) reaches 86* F, the ECM will start to pull timing, as much as 3* and pulls more timing as IAT's increase. All of which affects performance.
Old Jan 3, 2016 | 06:17 PM
timd38's Avatar
timd38
Why would you not want it? Keeps the heat out.
Old Jan 3, 2016 | 08:06 PM
ttx350z's Avatar
ttx350z
Makes a good tool shelf while you're working under the hood as well!
To Halltech 103 intake for LS7
