Manual Trans Question
Old Jan 7, 2016 | 12:57 PM
KenVette57's Avatar
KenVette57
Default Manual Trans Question
Hi All, I have an 05' C6 with manual trans. This thing is hard shifting, is that normal on stock early C6's? I have a 2 - 4 by pass installed. When shifting it's sometimes hard to get into next gear, and gear change, doesn't matter. Also on down shifts, not talking 6 - 2 at 70mph. I'm talking 3rd to 2nd at 30mph. Will an after market shifter like MGM make a difference or does the gear box need realigning or replacement. And yes, clutch pedal to the floor on shifts, Thanks
Old Jan 7, 2016 | 03:26 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Not to over simplify, but have you checked the clutch fluid level and is there any spillage of fluids around the area of clutch. If you don't already do the turkey baster "Ranger" method of keeping good fluid in the master cylinder, try that. There should be some external clue as to why it not dis-engaging completely.
Good Luck
Old Jan 7, 2016 | 03:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Clutch not disengaging properly is the first thing that comes to mind for me as well
Old Jan 7, 2016 | 03:57 PM
KenVette57's Avatar
KenVette57
Good Luck
Yeah, today is clutch fluid change day. Haven't changed it in a while, see what happens.. Thanks
Old Jan 12, 2016 | 10:15 PM
rpmextra's Avatar
rpmextra
And make sure you flush really good. A good oil doesn't hurt either. I like this one.
http://www.summitracing.com/int/part...6209/overview/
To Manual Trans Question
