Tire Size with OEM Wheels
Old Jan 14, 2016 | 11:38 AM
Jose2SS's Avatar
Jose2SS
Default Tire Size with OEM Wheels
Hello, I am trying to get the best tire size with the OEM Wheels. I want to purchase new wheels with the OEM size and looking to get a tire that can fill up more the space on height and wide. let me know what size can I get for that.
JC
Old Jan 14, 2016 | 11:58 AM
Mike's LS3's Avatar
Mike's LS3
JC
Base, GS, Z06, ZR1?
Old Jan 14, 2016 | 09:08 PM
Steve Haefner's Avatar
Steve Haefner
2018 C6 of Year Finalist
Originally Posted by Mike's LS3
Base, GS, Z06, ZR1?
We need more information my man.
Old Jan 17, 2016 | 11:51 AM
Jose2SS's Avatar
Jose2SS
Sorry, C6 with the sport package, big calipers. 2005
Thanks!!!
Old Jan 17, 2016 | 11:59 AM
Steve Haefner
Thanks!!!
So the 2005 base w/Z51, these should be your factory sizes yes?
F 245/40ZR18
R 285/35ZR19
F 18 x 8.5 +56
R 19 x 10.0 +79 (I believe)
Old Jan 17, 2016 | 01:18 PM
Steve Haefner
So here is what it would look like on the rear with 305's
http://www.willtheyfit.com/index.php...et2=79#content
and fronts with 265's
http://www.willtheyfit.com/index.php...et2=56#content
Not saying they will work, but this is a great tool to check things out. Good luck
Old Jan 18, 2016 | 11:06 AM
Jose2SS's Avatar
Jose2SS
Thanks a lot!!!
Old Jan 18, 2016 | 11:50 AM
Mike's LS3's Avatar
Mike's LS3
8.5" front rims = 255 recommended maximum tires.
10" rear rims = 295 recommended maximum tires.
Why not wider? Simply, because the additional width will roll up the shoulders of the tire causing instability at higher speeds.
Can it be done? Yes, but not recommended.
Go on Tire Rack and look up the tire size you plan on using, the recommended rim size is listed under specs. Then, you can go to the link provided above to check dimensions and speedo errors. Heck, you can plug in a 345 tire on a 2" rim and it will give you dimensions and speedo errors, but not the recommended tire/rim size you are asking.
Old Jan 19, 2016 | 01:39 PM
Jose2SS's Avatar
Jose2SS
Super, thanks for the response Mike, will go with your recommendations!!!!
Thanks!!!!
Old Jan 19, 2016 | 01:41 PM
Jose2SS's Avatar
Jose2SS
Thanks a lot Mike!!! This is great data. Should I keep the same height in the tire? What do you recommend?
Old Jan 19, 2016 | 05:45 PM
Mike's LS3's Avatar
Mike's LS3
It's best to stay around 1" to 1.4" difference from front to rear heights. Stock front to rear on the Goodyear EMT's list a 1.2" difference. Yes, it's also good to stay around the stock rear height which is 26.9" for the speedometer.
Michelin Super Sports 255/40/18 = 26" front diameter tire. (non run flat)
Michelin Super Sports 295/35/19 = 27.1" rear diameter tire. (non run flat)
Front to Rear Difference = 1.1" which is fine.
Height difference between the oem 285 tire and S.S. 295 tire is .2".
According to the speedo calculator the 295 tire with a 27.1 diameter at 60mph = 59.39 mph.
These are the tires I would run with the oem rims!
Old Jan 20, 2016 | 07:18 PM
Steve Haefner
and you can always tune the ECM for the new setup.
Old Jan 21, 2016 | 12:13 AM
Mike's LS3's Avatar
Mike's LS3
That's what I did for my 305's tires using HPtuners.
Old Jan 22, 2016 | 02:01 PM
Jose2SS's Avatar
Jose2SS
Thanks a lot Mike, this clarifies a lot of doubts that I had.
Old Jan 22, 2016 | 08:17 PM
Boomer111's Avatar
Boomer111
To Tire Size with OEM Wheels
