Harmonic Balancer. 6 Rib or 8 Rib
Old Jan 18, 2016 | 02:33 PM
XxDSGBxX's Avatar
XxDSGBxX
Default Harmonic Balancer. 6 Rib or 8 Rib
Ok I’m trying to get an ATI Harmonic Balancer for my 06 Z06. The stock balancer is 6 Rib in front and a 4 Rib A/C. Everywhere I look I keep getting an 8 Rib and 4 Rib A/C. I can’t run a 6 Rib built on an 8 Rib ATI Harmonic Balancer can I? I’ve check everywhere and I can’t find anything. Can someone help me out or let me know if I’m crazy.
Old Jan 18, 2016 | 02:43 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Why can't you just use 6 ribs of the 8?
On the cheapo Summit C2501 balancer that some (including me) use, they actually have 8 ribs, but the extra 2 are towards the rear of the car and are unusable.. but they're still there. So we are all using a 6 rib belt on a balancer with 8 grooves.
So, I don't see why you can't just use 6 of 8 for now.
Old Jan 18, 2016 | 03:12 PM
XxDSGBxX's Avatar
XxDSGBxX
I wasn't sure if you could run a 6 rib belt on an 8 rib Harmonic balancer. It just thrown me off that the ATI is 8 rib and not 6.
Old Jan 18, 2016 | 03:13 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I dunno.. might want to call them and ask first
Old Jan 18, 2016 | 03:23 PM
XxDSGBxX's Avatar
XxDSGBxX
Well if it's working for you then I don't see why it won't work for me but I will get better clarification.
Old Jan 18, 2016 | 03:54 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
They only make a 8 rib so you can use it on a NA car or blower car. Just use your 6 rib belt on it.
You are fine. Just have to pick std diameter or underdrive.
Old Jan 18, 2016 | 07:09 PM
Blk 08 C6's Avatar
Blk 08 C6
Im using a 8 rib overdrive damper right now n/a with a 6 rib belt.it works fine.but Im goin blown in a couple of months and it will be a 8 rib setup.
Old Jan 20, 2016 | 12:09 AM
XxDSGBxX's Avatar
XxDSGBxX
Ok thanks guys it just threw me off.
Old Jan 20, 2016 | 12:33 PM
ttx350z's Avatar
ttx350z
As said before, a 6 rib belt on an 8 rib pulley is balancer is fine.
Just make sure the belt is on the back of the balancer. The 2 ribs in front should be unused.
Old Jan 20, 2016 | 03:48 PM
XxDSGBxX's Avatar
XxDSGBxX
ttx350z. I know that thanks for the information.
To Harmonic Balancer. 6 Rib or 8 Rib
