I really like all of the stuff on the motortrend channel. One thing I'm wondering is if these results would change if they ran it through an exhaust with any kind of backpressure.
The rest of the exhaust system is every bit as important as the headers.
However, if the shape of the tubes had no importance, then neither would the diameter. The fact that their test had an increase in HP with mild restrictions, was also an indication the that tube size was initially too large for that particular application. If you noticed test A vs B, the RPM required to get a nearly identical HP was 500 higher, because the unbashed headers were not flowing well after 5800 RPM, due to too much area to fill and retain high velocity. Too big is just as much of a problem as being too small. The assumption they made, was that the headers they used were ideally sized for that engine and they were not.
Those headers are for high end power. For example on our LS engines we have 3 sizes that I know of. 1 5/8" runners 1 3/4" runners and 1 7/8" runners. I selected 1 3/4" so I would keep low end TQ Those headers on the video could very well be designed for top end power. Basically just moving the power band from down low to up top.
Welcome.
Here is the diference on a H&C LS2 1 3/4" vs 1 7/8" this was done with no tuning changes other then the maff making the changes
Always wanted to see someone do this. Thanks. Looks to be around 30 Ft. Lbs. difference in TQ. That graph makes me want to swap to the LG 1 7/8" long tubes. Once again thanks for posting. From that graph it does not look like power band moved but did gain.
Unless I'm mistaken, Mr. Dennis lost torque with the 1 7/8".....?
Unless I'm mistaken, Mr. Dennis lost power with the 1 7/8".....?
Yep lost 20 RWTQ after maff adjusted and only gained 5 RWHP from 6800 rpm to 7200 really not enough to change to the 1 7/8" with that TQ loss on the drive home i could really feel the TQ loss, so didnt even run at the track swapped back to 1 3/4" I have most bolt ons and a serdi valve job stock valves cartek ported heads cartek cam 11.1 maybe 11.2 still 93 pump gas and an A4 373 gear with 3800 PA converter in a manual it would have easily dyno over 500RWHP and more RWTQ
