C6 ZO6 Carpet removal
Does anyone have carpet removal instructions for the rear and behind the seats of a C6 ZO6? Pictures and or video would be helpful.
Thanks,
G
Thanks,
G
Race Car Tech
Follow the post #2 and #7 for the rear area carpet removal of the attached thread link.
As for the carpet behind the seat, move your seats as forward as they go, then you can pull up and away the carpet from behind the center console, and the seats. It's a moulded carpet that sits on top of the bump behind the seats, and the carpet slips under the center console.
If the carpet is too tight to come out from around the center console, loosen the 2 rear bolts (under the plastic caps) inside the console so you can free the carpet away from the console. Most times, it slips out and back in with no issues.
https://www.corvetteforum.com/forums...t-removal.html
Good Luck
I have a 2008 coupe with the two cargo compartments one on each side. I have followed your instructions from above and have removed the doors to the compartments but when I try to pull them up they won't come up. Are they attached with some sort of fastener?
Race Car Tech
You'll have to gently pry up the storage box cover frames. These are particularly fragile, so use the tool to pry directly adjacent to the clips or you'll snap the frame. Once those are free, you should be able to remove the rear carpet piece.
