BAP, which one?
Old Feb 7, 2016 | 06:58 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Default BAP, which one?
I want to order a BAP (boost a pump) but I don't know which one to go with? coz I want to spray 150-200shot (wet) on stock fuel pump
Please I need the answer asap guys.
Old Feb 7, 2016 | 12:58 PM
DSOMC6's Avatar
DSOMC6
I've had three different brands in the last 9 years. The first two lasted maybe two years each.
Purchase a KB (Kenny Bell) bap. Rarely if ever have I seen one fail that was wired correctly. My KB bap is over five years old and has been flawless. Great company/customer service as well if you ever need to call them for tech support.
Old Feb 7, 2016 | 02:01 PM
xBoostx's Avatar
xBoostx
Default I have one for sale...
https://www.corvetteforum.com/forums...st-a-pump.html
Old Feb 7, 2016 | 04:16 PM
Dano523's Avatar
Dano523
Instead of just over working the OEM pump with a BAP to wear it out faster, if you change out the pump in the tank to the correct output size to begin with, going to be less problems in the long run instead.
Hence with NOS, it not IF, but WHEN you are going to have problems to blow a motor, and no reason to just throw another monkey wrench in the tire spokes to have the problem sooner instead.
Old Feb 7, 2016 | 05:06 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
A properly installed KB BAP will rarely if ever give problems and not hurt the pump. Install it using a ractronix harness and you will be good to go.
Mine has been fine for 4 years now and I know many people running then with no issues.
Old Feb 8, 2016 | 05:07 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Sure I'm going with KB BAP
I sent to them just know to see which one I should go with
Old Feb 8, 2016 | 05:14 AM
ZHZ-416ci's Avatar
ZHZ-416ci
https://youtu.be/-1cPuJza_Aw
Fuel pumps and fuel system will destroy my budget
may be in the future I'll think about a complete fuel system
and spraying 150 with BAP support I think it's not that risky
Old Feb 8, 2016 | 05:21 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Thanks for adding ractronix harness point
do you have the part# of your KB BAP?
BTW finally next week I'll get my Weld wheels
Thanks for all info that you gave it to me.
Old Feb 8, 2016 | 06:58 AM
xBoostx's Avatar
xBoostx
I don't know any body who had a pump go bad as a result of KB boost a pump and else the Racetronix harness is unnecessary as the pump feeds directly from the battery to increase the juice to the pump and comes with all necessary top notch hardware.
Old Feb 15, 2016 | 04:22 AM
ZHZ-416ci's Avatar
ZHZ-416ci
I sent an email to Kenne Bell, and told me to go with KB89068
SO
What is the best source to buy it?
To BAP, which one?
