Squeaky brakes
Old Feb 20, 2016 | 07:22 PM
FirstTimer Pops's Avatar
FirstTimer Pops
Default Squeaky brakes
My 2013 Grand Sport's brakes squeak with normal application. Only if I barely press on them to slow down will they not squeak. If I press harder, they squeak louder. I did clean the wheels the other day and the squeak went away for a few days, but it returned.
Normal condition? Learn to live with it? Get it checked out under warranty?
Thanks for the time,
Pops
Old Feb 20, 2016 | 09:27 PM
RicK T's Avatar
RicK T
Squeaky brakes are pretty common with the factory pads. Many switch to ceramic pads and in most cases that significantly reduces or eliminates squeaks, but it does cost money.
I suggest you try "bedding" your current pads.....that is.....heat the pads up enough to deposit a nice layer of pad material on the rotors. It doesn't cost anything and it may work.
This is a general procedure, some specific pads and materials require a little different but this is good for stock. You will need to plan a time and place to do this so that you don't impact other drivers and no one else impedes you:
Make 8 - 10 repeated stops from approximately 45 MPH down to 20 MPH, applying moderate/hard pressure.
DO NOT DRAG BRAKES! DO NOT COME TO A COMPLETE STOP! YOU WILL BE ABLE TO SMELL THE HOT BRAKE PADS! IF YOU DO HAVE TO COME TO A STOP DON'T HOLD THE BRAKE PEDAL, USE THE E-BRAKE MOMENTARILY!
Drive for at least 15 minutes without using the brakes to allow cool down.
