My SC'd meth inj c6z is backfring under heavy throttle anything around or over 4k rpms. Anything below 4k is fine. What do you guys think would be the issue? Tune? I plan on pulling plugs, unplugging/clean the maf when I get home, and possibly pulling the valve covers. Any input would be great!
Thanks!
Weak ignition.
Too lean
Could be lots of things, I would start there
It ended u being a bad spark plug wire. It would not stick on the spark plug. At wot the engine would shake it loose. as usual you guys are awesome. Appreciate the help
