Navigation unlock
Old Feb 24, 2016 | 10:06 AM
hitekcm's Avatar
hitekcm
Default Navigation unlock
I have a 2011 ZR1 that came with OnStar and Xm radio.
I would like to swap the radio for a Navigation unit but remain with the stock Denso style corvette navigation unit.
I purchased a Denso unit that came from a 2008 ZO6 and it worked when I fist plugged it in but after unplugging it the "Theft Lock" appeared on the screen.
I tried looking on ebay for unlock services and checked with a couple Chevy dealers but have not found anyone that says they can unlock it.
Anyone done this?
Old Feb 24, 2016 | 10:18 AM
whitehooptie's Avatar
whitehooptie
Need a Tech 2. Dealership has to do it. If you were around Dallas, I own one and would do it for free. It takes 5 minutes if that.
Old Feb 24, 2016 | 11:59 AM
GMJim's Avatar
GMJim
Check your other post here.
https://www.corvetteforum.com/forums...on-unlock.html
Old Feb 24, 2016 | 03:47 PM
Kent1999's Avatar
Kent1999
The at-home workaround that has been posted in similar threads is for *older* radios (entering codes for the Theft-Loc system in C5 and prior), and will NOT work on a C6 radio.
Old Feb 24, 2016 | 06:14 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Anyone done this?
Hi hitekcm,
I apologize for any inconvenience caused as a result of this situation. If you would like, I can certainly look into this "Theft Lock" concern on my end and locate a different dealership in your area. Please send us a private message along with your full contact information, current mileage, VIN, and zip code if this is something of interest.
I hope to hear from you soon.
Julie C
Chevrolet Customer Care
Old Feb 27, 2016 | 09:33 PM
hitekcm's Avatar
hitekcm
Default Theft lock
Originally Posted by Chevy Cust Svc
Hi hitekcm,
Julie C
No problem thanks Julie , I'm new here and don't know how to PM you but I have nothing to hide from CF.
2011 ZR1, 11,000 miles, vin# 1G1YM2DT1B5800537
Clint Mitchell .P.O. box 136 , Port costa , ca 94569.
925=330-0682
Old Feb 29, 2016 | 03:04 AM
Kent1999's Avatar
Kent1999
Anyone done this?
FYI -- your 2011's bluetooth steering wheel controls and pairing (if BT equipped) will most likely no longer work if you swap a 2008 radio into your 2011. (2008 OEM radios don't support BT... I think you need a 2009 or newer unit).
Old Feb 29, 2016 | 11:03 PM
hitekcm's Avatar
hitekcm
Thanks for the info
To Navigation unlock
