Dexron III
Old Feb 25, 2016 | 05:49 PM
Timothy Barth's Avatar
Timothy Barth
Default Dexron III
I am about to change the auto trans fluid in a 2005 c6. The owners manual calls for DexronIII. Is this fluid still available or can I use DexronVI ?
Old Feb 25, 2016 | 06:33 PM
timd38's Avatar
timd38
Dex VI is much thinner.
Try this and you won't be disappointed.
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
Old Feb 25, 2016 | 06:51 PM
RicK T's Avatar
RicK T
Use the VI.
Here is the GM announcement of the VI and it states right at the beginning that it is backward compatible with prior trans:
(the thread is titled wrong, saying dexron 4, it is actually 6)
https://www.corvetteforum.com/forums...exron-4-a.html
Old Feb 25, 2016 | 06:56 PM
timd38's Avatar
timd38
Originally Posted by RicK T
Use the VI.
GM did it to reduce SKUs, if you look at the viscosity difference between the two, you would want Dev III.
Old Feb 25, 2016 | 07:55 PM
Timothy Barth
What are SKU's?
Old Feb 25, 2016 | 08:21 PM
RicK T's Avatar
RicK T
What are SKU's?
Stock Keeping Unit = product inventory control number
Old Feb 26, 2016 | 07:54 AM
GOLD72's Avatar
GOLD72
I assume your car is an auto transmission?? If yes, Dexron 6 can certainly be used though the original spec was for Dexron III. If it is a 6-speed manual stick, absolutely do not use Dexron 6 as it is too thin for manuals. There are plenty of aftermarket fluids that meet Dexron III specs that are acceptable for the Tremec manual trannies.
Old Feb 26, 2016 | 01:03 PM
JoesC5's Avatar
JoesC5
Mobil1 dexIII synthetic ATF is available.
Old Feb 28, 2016 | 08:07 PM
cclive's Avatar
cclive
100% If it is an auto trans then Dex VI is fine, but if it is a manual, you should absolutely not use Dex VI...use Dex III only. There are many ATF fluids out there that meet Dex III specs but not Dex VI specs...these are the ones to use. I used Mobil One Synthetic ATF, which specifically says that it meets Dex III but not Dex VI. Dex VI has a lower friction coefficient which does not work well with the synchros in a manual trans. It was made to increase gas mileage in automatic transmissions. Mine is a 2007, and Dex VI had been out on the market for years at that point, but mine has a sticker right next to the fill plug that says use Dex III only...they did this for a reason.
Old Feb 29, 2016 | 02:41 PM
Timothy Barth
Mine is an 4sp automatic. If you drop the pan and replace the filter, how much fluid will you have to replace?
Old Feb 29, 2016 | 05:57 PM
timd38's Avatar
timd38
Originally Posted by glass slipper
It was not done to reduce SKUs, GM had to come up with a new fluid/SKU for manual transmissions that used Dexron III before. GM stated Dexron VI is backward compatible with Dexron III first and foremost because it is and secondly because GM stopped monitoring the Dexron III specification after Dexron VI came out meaning any Dexron III transmission fluid you buy today states it meets the Dexron III specs, it does not say it has been approved to the Dexron III specs because GM doesn't even monitor the spec now. If you buy fluid stating it meets the Dexron III specs from a good company like Amsoil or Mobil, you'll be OK.
While there is a difference in viscosity between the Dexron VI and Dexron III when new, the big change when GM went to the Dexron VI is stable viscosity over the life of the fluid. Dexron III actually shears down in viscosity and quickly becomes "thinner" than Dexron VI. There were many other improvements made to Dexron VI vs Dexron III, it's really a no brainer to make the move to Dexron VI when changing automatic transmission fluid in cars originally calling for Dexron III. Dexron VI is a substantial upgrade over Dexron III plus Dexron VI enjoys the added benefit of GM monitoring the spec while you're pretty much on your own with Dexron III.
I am not going to debate it, but we compared Dex III to Dex VI and kept them both. The new Dex HP is almost all PAO and Red Line Dex III and Dex VI is almost all PAO. Look at the centistokes of the different and you will want a PAO lube.
Old Feb 29, 2016 | 08:26 PM
cclive's Avatar
cclive
Good, then Dex VI is fine. The owners manual says 11.4 quarts, but the converter will not drain so it will be less than that. I don't have a service manual for '05 so I can't tell you how many quarts...but my rule is to buy more than needed and then return the unopened bottles. Someone will chime in with the right amount of fluid.
Old Mar 1, 2016 | 12:15 AM
jft69z's Avatar
jft69z
For a 2005 the GM eSI says - Overhaul: 10.8 qts & for Pan removal: 5.0 qts.
Old Mar 1, 2016 | 11:29 AM
cclive's Avatar
cclive
Thanks for adding that. Since we can't get the fluid out of the torque converter in order to replace it, what I do is to drain the trans, change the filter and then refill it. This replaces ballpark about half the fluid. I then drive the car for a day and then just drain the fluid again and replace it. This isn't difficult because the second change is just the drain plug and not the pan being removed. Five or six quarts of fluid is not expensive so I don't worry about this extra expense. I did this with my old chevy blazer at 50K, 100K and 150K and the trans was still perfect at 175K when I sold it. Changing the fluid twice doesn't get it all replaced but I feel like it is better than only changing the half that comes out the drain plug.
To Dexron III
