Mantic 9000 clutch slave cylinder
Received 1,194 Likes
St. Jude Donor '15
GM ones come full of fluid, no need to bleed. Add a remote bleeder if you want to be able to do it later if needed.
schpenxel (11-10-2020)
FYI, before bolting in the torque tube, put a flat edge on the back of the bell housing, measure from that edge to the fingers on the pressure plate.
Then push the TB bearing all the way down/towards the torque to to compress the TB spring, and measure the distance from the front of the TB to the face of the torque tube plate.
What you want is to have free lash of around .124"~/.150", so the TB compressed all the way back on it spring, is not being shoved into the pressure plate fingers as you are bolting the torque tube in place.
Go to post #35.
https://www.corvetteforum.com/forums...uestion-2.html
Go to post #35.
