Run Rough and Traction control message
Old Mar 11, 2016 | 01:56 PM
flyint's Avatar
flyint
Default Run Rough and Traction control message
Just out for a drive in my 2013 GS Coupe. Stopped at grocery store and when got back in car and fired it up there was a clicking noise coming from under the hood and the check engine light illuminated along with the check Traction Control at the same time.
Does anyone have a clue as to what might have happened. I don't drive the car hard or anything.
Thanks in advance
Old Mar 11, 2016 | 02:04 PM
4SUMERZ's Avatar
4SUMERZ
Thanks in advance
Without much to go on, the first thing I would check is to see if all the plug wires are on tight. That would cause lot's of issues and alarms.
Good Luck
Old Mar 11, 2016 | 02:06 PM
flyint's Avatar
flyint
Thanks... that was the first thing I checked. Only have 12000 miles on the car. I figure it must be something electronic...just baffling
To Run Rough and Traction control message
