Harmonic balancer failure
Old Apr 5, 2016 | 12:35 PM
Never9Fast3Enough's Avatar
Never9Fast3Enough
Default Harmonic balancer failure
Noticed a small oil leak on my 2006 and started looking for the culprit. I was very surprised to find that the outside ring with the assesory belt and AC belt drive had slipped back to the block approximately 1/2 inch and has cut something (haven't gotten it apart yet) that has caused the oil leak. The photos aren't great, but you can see the pulley up against the block and the belts riding on the edge do the pulleys.
I have done some looking on the Forum and elsewhere and am probably going to do the repair myself even though it is pretty involved.
Thoughts on after market balances? I notice that GM has discontinued their unit.
Anybody ever seem this type of failure?
Thoughts on what the pulley cut to cause my oil leak?
Old Apr 5, 2016 | 01:07 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I think everyone has seen that failure... very common
You can either go high end, i.e. IW / ATI for a new balancer or cheaper and use part number C2501 from summit. I think powerbond has some options too but I've heard they are back ordered quite a ways
I did the C2501 a year and a half ago and it's been fine, even with a supercharger. You'll have to replace the front timing cover seal and maybe even the front timing cover depending on whether the balancer wore into the cover.
Obviously don't run it anymore like that. The AC belt came off on mine and managed to break the AC clutch connector in the process, so I had to replace the AC clutch too, which was a royal pain. Hopefully yours just needs a new balancer/seal.
Old Apr 5, 2016 | 01:29 PM
Never9Fast3Enough
Thanks for the feedback. I was thinking ATI, but I bet when I compare prices, I'll be looking at the Summit unit. I would think that any reputable after market would be better than came on the car.
Old Apr 5, 2016 | 01:52 PM
genolan's Avatar
genolan
What year was this fixed in? I have a 2008 and was wondering if I may also be at risk?
Old Apr 5, 2016 | 02:13 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
It wasn't fixed. I had to replace the balancer on my '12 at 4k miles.
Old Apr 5, 2016 | 02:29 PM
Spoolin8's Avatar
Spoolin8
Ive owned two vettes and had to replace the balancers on both. Did the first vette myself and paid a shop to have the 2nd done. Went with ATI ones and never looked back. Anyone that hasnt seen this failure, hasnt drove the vehicle as it was designed
Old Apr 5, 2016 | 03:00 PM
Never9Fast3Enough
Just ordered the Summit unit, installation tool and bolt. My car has 152000 miles which sounds like a lot on the original h-balancer. I noticed the slight wobble, but Chevrolet says "don't worry about it". Wished I had fixed it before it rubbed a hole in my timing chain cover.
Old Apr 5, 2016 | 03:02 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I just replaced the balancer on my '05 after 141,000 miles...I had my dealer do the work since I get 12 months and unlimited mileage on the part; if it fails, the dealer picks up the check.
I have put 2,200 miles on it since the work was done and my road trips left for this year will total somewhere in the neighborhood of 8,000 miles. If it takes another 140,000 miles before it needs replacement, I can live with that...
Old Apr 5, 2016 | 03:05 PM
Never9Fast3Enough
Glad to see I am not the only one who racks up the miles. Perfect car for a road trip!
Old Apr 5, 2016 | 03:49 PM
dbielicke's Avatar
dbielicke
Had mine replaced at 72,000 with the ATI. Put another 2k on it since and everything seems to be working out fine. I had a mechanic neighbor tell me to go with the ATI. He said they make the best so I took his word for it.
Old Apr 5, 2016 | 03:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Changed mine around 140 or 150K.
Old Apr 5, 2016 | 08:43 PM
Never9Fast3Enough
I almost hate to ask, but should I consider doing anything to,the timing chain and gears with 150k miles?
Old Apr 5, 2016 | 08:52 PM
backlash2032's Avatar
backlash2032
Powerbond is not backordered. Atleast the 25% underdrive. Got mine in 3 days, drop shipped from the manufacturer.
Old Apr 5, 2016 | 09:29 PM
walleyejack's Avatar
walleyejack
well, you are in there. you have it apart, i would say good idea and maybe oil pump.
Old Apr 5, 2016 | 09:39 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's a coin toss IMO. Chain/gear looked fine on mine at similar mileage. Oil pressure didn't change significantly with a new pump (used a stock volume/stock relief spring though so that's at least partially why)
Old Apr 6, 2016 | 04:43 AM
mikeyyyallday's Avatar
mikeyyyallday
how much did parts & labor set you back?
Old Apr 6, 2016 | 04:45 AM
mikeyyyallday
are there any noticeable performance symptoms the car may have before the harmonic balancer fails? most of you guys seem to have the problem 100k+ miles but jus saw a comment about it failing at 4k miles as well. my car has 71k miles, anything to worry about? or does it jus happen randomly lol.
To Harmonic balancer failure
Old Apr 6, 2016 | 08:18 AM
walleyejack
IMO, the h/b failure is blown
way out of proportion, same as LS7 heads, just over hyped, sure it happens, so do flat tires and squeaky roofs and hvac. don t worry about it, check it every 5 yrs and drive it and enjoy.
Old Apr 6, 2016 | 10:03 AM
dbielicke's Avatar
dbielicke
I was at $1100 after the ATI balancer and labor. Based on my previous questions on the forum, that was right about average. I know people got it done for less and some for more. But I had planned on $1200.
Old Apr 6, 2016 | 10:35 AM
CMY SIX's Avatar
CMY SIX
some of you guys got took too the cleaners, I had the powerbond SFI unit and vengeance racing installed it for $290,
