E-Force Blower
Old Apr 7, 2016 | 09:57 AM
RT2SJB's Avatar
RT2SJB
Default E-Force Blower
Can someone recommend a shop in San Antonio TX to install an E-Force Blower on my 2011 GS automatic? Has anyone installed one and is it worth the cost for the return on performance?
Old Apr 7, 2016 | 02:57 PM
Dano523's Avatar
Dano523
With meth kit, your good for around 650hp on the motor,
The glitch, finding a shop that can install/tune a mod'd stage 2 kit with Meth kit to get you to 650hp, then the needed upgrades to the drive line so your not blowing it up next.
As for the stock stage 2 kit with the can'd tune that comes with it (600hp), it not a bad deal, but with repeat boost hits, going to heat soak pretty quick instead (heat soak ends up with less power).
On a side note, the canned tune that comes with it does lean more heavy on the TM.richer side, so it not like your going to burn the tires off the rims quickly instead.
Old Apr 7, 2016 | 09:25 PM
darkknight91's Avatar
darkknight91
Have the eforce blower on my '10 6 spd..its only on 7lbs right now..i blew my clutch about 2 months after i got the blower.....if you don't beat the snot out of it your tranny should hold ... look up "realcanuk" he had the blower with an automatic.. should find some good info through his past posts.....
To E-Force Blower
