Popping noise while accelerating.
Old Apr 25, 2016 | 05:18 PM
VETTSM's Avatar
VETTSM
Default Popping noise while accelerating.
I have just upgraded to a 2010 Z06. I have 14K miles on the car. While aggressively accelerating between 3K and 6K I have some popping noises from engine bay. This only happens when I get on it hard through the gears. I had heard that they had head / valve problems with the LS7. I am reaching out to see if someone could give a little advice?
Thanks in advance
Old Apr 25, 2016 | 05:54 PM
extrapilot's Avatar
extrapilot
When the popping noise happens, due you feel a loss of power? Could be just a loose spark plug wire creating a miss-fire. They can come loose from either the coil and/or spark plug side, so you may have to pull the fuel rail covers to see.
You should also post over at the ZO6 Discussion forum, as more owners probably hang out there..
Old Apr 25, 2016 | 07:18 PM
Brandon619's Avatar
Brandon619
I've had a similar issue with a bad plug wire. I did a header install and when I rev'd my motor out it would stutter but no codes and it drove great at low rpm. I would replace your plug wire and check your plugs in my opinion.
Old Apr 26, 2016 | 03:43 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Thanks in advance
Hello VETTSM,
We are sorry to hear of the popping noise you are currently experiencing and would like to check for any recalls or service announcements that may be related to this. If interested, please send us a private message with your VIN!
Best,
Erica W.
Chevrolet Customer Care
Old Apr 27, 2016 | 02:38 PM
VETTSM's Avatar
VETTSM
Originally Posted by Chevy Cust Svc
Hello VETTSM,
Best,
Erica W.
Message sent... Thanks...
Old Apr 28, 2016 | 03:02 PM
Chevy Cust Svc
You’re welcome, VETTSM!
I see that we have responded to your message with some additional details. Feel free to send us another message if you have any questions.
Kindly,
Julie C
To Popping noise while accelerating.
