Gear does not shift!
Old Apr 26, 2016 | 10:48 AM
VetteArts's Avatar
VetteArts
Default Gear does not shift!
Supercharged A6 c6 2008.
Suddenly gear stuck in 2nd and won't shift up or down. Switched off and on and problem gone but code is appearing. What does this mean! On inspection got this:
Old Apr 26, 2016 | 12:17 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Did a "Google search" on the code & came up with the following:
(the full document is at "http://www.ls2.com/boggs/dtcs/DTC%20P2723%20or%20P2724.htm"
DTC P2723 or P2724
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P2723: Clutch Pressure Control (PC) Solenoid 5 - Stuck Off
DTC P2724: Clutch Pressure Control (PC) Solenoid 5 - Stuck On
Diagnostic Fault Information
The following fault table will help determine if a hydraulic circuit or an incorrect position of a valve train component affects the transmission operation.
Component
Cause
DTCs
1-2-3-4 and 3-5-R Clutch Housing Assembly
1-2-3-4 clutch backing plate retaining ring not seated, causing the piston to over-travel and cut 1-2-3-4 clutch piston seal
P2723
Lower Control Valve Body Assembly
Clutch select valve 3 stuck OFF - debris, sediment, binding or scored bore
P2723
Upper Control Valve Body Assembly
1-2-3-4 Clutch regulator valve stuck - debris, sediment, binding or scored bore
P2723
Fluid Pump Cover Assembly
Fluid pump cover pump damage or debris between torque converter housing causing pump slide damage
Fluid pump cover vanes and fluid pump rotor broken
P2723
Circuit/System Description
The clutch pressure control (PC) solenoid 5 is integral to the control solenoid (w/body and TCM) valve assembly and has no serviceable parts. The PC solenoid 5 is a normally high-pressure control solenoid which provides fluid pressure to the 1-2-3-4 clutch regulator valve. The TCM controls the solenoid pressure by regulating the exhaust fluid. When the TCM commands the solenoid off, the exhausting fluid is stopped and the 1-2-3-4 pressure is high. When commanded on, the clutch PC solenoid 5 regulates the amount of exhausting transmission fluid. Solenoid power is supplied by the TCM through a high side driver (HSD). The HSD protects the circuits and components that the TCM powers. Should the circuit overload the driver will shutdown. After the overload is removed the HSD reset.
Old May 13, 2016 | 07:42 AM
VetteArts's Avatar
VetteArts
Just to update you. I have changed the Trans fluid. It was less than required level. I was told it causes similar issue. Now it is normal, but am not going full throttle due high boost problems.
Old May 13, 2016 | 08:21 AM
let er eat's Avatar
let er eat
Moar boost = Moar power. .. let er eat!!!
Old May 13, 2016 | 09:30 PM
klwehunt's Avatar
klwehunt
Had that to happen on my 08 and they replaced the shift solenoid and some of the valve body.
Old Jun 30, 2016 | 06:04 PM
VetteArts's Avatar
VetteArts
Problem is back now.
Error is p2724
Solenoid valve 5 stuck on. It goes into limp mode. I changed the "solenoid pack" and filter but came back in a day time.
Could this be mechanical or is that pure electrical?
To Gear does not shift!
