Lifter bleed down ?
Old Apr 30, 2016 | 11:28 PM
walleyejack's Avatar
walleyejack
Default Lifter bleed down ?
is possible to have a lifter bleed down at any given time ? cold start up it may be there or may not, or driving along with the engine at operating temp and come to a stop light, waiting, and the all of a sudden it starts, i can hear it easily over the radio, pull away and get some rpms and still hear it a bit, then goes away, may not hear it the rest of the day. Ocassionaly i will here it at warm start up, give a few minutes of driving and seems to be ok. is this something i should be concerned about, or just keep an ear on it. i just did a cam swap in January, and am thinking this has something to do with it.
all opinions welcomed.
TIA Al
Old May 1, 2016 | 11:17 AM
CMY SIX's Avatar
CMY SIX
it sounds like a bad lifter, let me guess you put in dual highlift springs? with a very high seat pressure.
Old May 1, 2016 | 01:41 PM
walleyejack
Dual 660 lift sptings. Is that creating a problem ?
Old May 1, 2016 | 02:01 PM
double06's Avatar
double06
Default Do you have - Stock lifters?
I think when they get over 400 pounds of open pressure problems begin to arise with the stock lifters.
Old May 1, 2016 | 03:01 PM
CMY SIX's Avatar
CMY SIX
Old May 1, 2016 | 05:33 PM
walleyejack
change out the lifters then, is what you suggest before it gets nasty, or wait a bit and see if it gets worse ?
Old May 1, 2016 | 07:18 PM
let er eat's Avatar
let er eat
why risk it...change em out before things start to break.
Old May 1, 2016 | 08:32 PM
walleyejack
if i take the heads off, i may as well shave them down a bit.
Old May 2, 2016 | 06:02 PM
CMY SIX's Avatar
CMY SIX
then you'd better know what your doing with gasket thickness or pushrod length or both, can't just flycut the heads and put it back together the way it was
Old May 2, 2016 | 06:21 PM
walleyejack
No, i m not shaving them, change lifters and i good.
To Lifter bleed down ?
