Brake Hardware
Old May 14, 2016 | 06:28 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default Brake Hardware
People talk a lot about what are the Best pads for their car but I never hear anyone talk about the hardware.
I'm going to replace the hardware on my 08 Z51 front and rear brakes. Is there a "best" for the hardware? I was looking online at the typical stores advance, autozone , orielly's and none of them have these clips in stock so if I need to order them I want to order the best I can. I see some are just steel and others are rubber coated. What do you guy's use, think , have an opinion on?
Old May 14, 2016 | 06:48 PM
EVRose's Avatar
EVRose
The clips are usually included with the new pads.
Old May 14, 2016 | 08:50 PM
ls1121's Avatar
ls1121
I'm not doing pads I just want to replace the clips to try and reduce the noise.
Old May 16, 2016 | 06:40 AM
05 Wreck's Avatar
05 Wreck
Check RockAuto catalogue:
http://www.rockauto.com/en/catalog/c...dware+kit,1736
Old May 16, 2016 | 08:22 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Rather than just changing the hardware pieces (which are not expensive), apply a thin coat of hi-heat grease to the wear points & the backside of the pads. Be careful not to get any on the face side of the pads or the rotors. The grease will dampen high frequency vibration which is often the cause of brake squeal.
Old May 16, 2016 | 06:07 PM
ls1121's Avatar
ls1121
Bingo.....that was the plan however if I am going in there I want to replace the clips. I bought some on ebay that are coated just was wondering if there was a "better" clip. thanx for all the replies guy's.
To Brake Hardware
