Line lock issue
Old May 16, 2016 | 07:28 AM
corvettepower's Avatar
corvettepower
Default Line lock issue
Is it normal to do a burn out using line lock and the abs light and traction lights come on. I like to race with the abs active but I don't want to have to turn car off and back on to reset the bcm so the lights will go off.
Old May 16, 2016 | 08:47 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Can't help with the cause of the issue, but I can tell you my line loc never sets off my ABS light. I turn off the traction control when doing the burnout and racing though.
Old May 16, 2016 | 09:38 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
See if it happens if you turn off both TC and AH by holding the button down. When my car was on the dyno it would throw all sorts of ABS lights if I just turned traction control off but left active handling on for some reason, and using linelock is a very similar situation for the car.
Old May 16, 2016 | 09:43 AM
jesse82nc's Avatar
jesse82nc
Yes, same as the dyno. The rear wheels are spinning, the front are not, it freaks out basically.
Old May 16, 2016 | 10:17 AM
corvettepower
Ok thanks I'll try that and get back with you on the results
Old May 16, 2016 | 09:34 PM
irok's Avatar
irok
my cars never sets any lights using the line lock or on the dyno.turn traction control off on dyno
Old May 17, 2016 | 01:47 AM
corvettepower
I have a 2011 gs m6 and the line lock is coming st8 off the master cylinder goin to the bcm hot wire to hot side of alternator and ground ran in car to button . Do it sound like same way all y'all have it hooked up? It doesn't come on til after I have applied brakes and holding button. Wen I let off brakes and holding button the lights come on. I'm still at work so I haven't tried with the active handling and tc all off yet.
To Line lock issue
